EM TuningAH Fabrications
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question Orange oil sensor light - 1.9 TDI 130
    Hi guys.
    The orange oil sensor light just popped up on my dash. Checked the oil level via the dipstick and it's full (just had an oil change 800miles ago) and I have checked the fuse (#5) which is fine.
    Faulty sensor?
    *WANTED* AUDI CD PLAYER
    Jun 2011
    130
    Quote Originally Posted by AUDIESEL View Post
    Hi guys.
    Faulty sensor?
    i reckon the sensors just come loose
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Any way to address this without dropping the 800mile-old oil?
    Apr 2006
    DORSET ,ENGLAND
    13
    Hi,
    I had the same fault on my 2.0 FSI A4. It was the oil level sensor that I had to change to rectify the fault.
    The sensor was located at the bottom of the sump so had to dump all the oil. If you can, plug a diagnostic tool in and it will tell you which sensor is at fault.
    i_786_i's Avatar
    Aug 2012
    57
    Hi,
    You will have to drain the oil if it is the sensor, but just pour into a clean container and re-use (the oil filter should be able to get rid on any debris).
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    639
    Quote Originally Posted by i_786_i View Post
    Hi,
    +1
    Buy a £1 wash bucket and use that
  1. OIL SENSOR LIGHT
    By boomtown in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd November 2012, 10:15
  2. Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    By i_786_i in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th August 2012, 23:31
  3. Oil sensor light, 03 1.8t B6, help me
    By sminkie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th April 2011, 14:44
  4. Oil Leak on TDi 130
    By Karcsi in forum Diesel forum
    Last Post: 30th January 2007, 18:35
  5. A4 TDI 130 Oil Consumption
    By neiltdi in forum Diesel forum
    Last Post: 16th December 2003, 09:25
