Volks AutosEM Tuning
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    audi A4 found three fault codes
    as title says just done a scan only have one of those cheap fault code readers of fleebay (need vagcom) but yes its found three fault codes under the engine section.
    17698
    16396
    17704
    any ideas guys
    dplovin's Avatar
    Jan 2011
    cheshire
    359
    Quote Originally Posted by dplovin View Post
    17698
    16396
    17704
    any ideas guys
    just done a search and i think to of the codes are pointing towards the temp cooling sensor of sumat like that.
    the other is camshaft tensioner hmmm, has had a cambelt changed a few thou back maybe they didnt clear the code after they changed it
  1. audi a3 1.8t fault codes?
    By quattrosport14 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2010, 16:30
  2. Removing Fault Codes on Audi 80
    By Spoon in forum General Technical / How To
    Last Post: 18th August 2008, 17:44
  3. Fault code on Audi S3 Central locking
    By jesters3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd September 2007, 20:37
  4. Audi a6 fault codes
    By gt-ne in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th August 2006, 13:14
