AH FabricationsSky Insurance
    Oct 2012
    MULTITRONIC PROBLEM ... SURPRISE ... SURPRISE
    Hi
    Can anyone help ?
    I recently bought a 2004 B6 Audi A4 1.8t multitronic (63,000) from an independent dealer , on my way home the gear selector lights on the dash started flashing then stopped and highlighted D for drive as normal , also which happens often is it will slip into Sport mode on its own accord while the gearbox indicates drive ??? It has a 3 month warranty thank goodness , just wondered if anyone has had a similar problem ?
    thanks in advance
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    check if it's had the recall and 7 plate conversion (it was NOT standard on 1.8T's, especially low mileage ones!).... if not, then 60k is a fairly typical time for that gearbox to go pop and it's a £1500 fix... assuming the seller won't stump up for that, then best to get your money back and walk away.
    LostBok/BahnStormer77
    Oct 2012
    Hi Many thanks for your reply
    No it's still got the original 6 speed gearbox , it's going in this week for to have a new ECU ? does that make sense ?
    Thanks in advance
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,258
    ECU is one of the main faults on that gearbox, As above check that it has had the 7 plate clutch upgrade not 6 speed
  1. Multitronic Problems - Big Problems!
    By Katherine B in forum General Technical / How To
    Last Post: 8th November 2013, 06:45
  2. multitronic problems
    By imported_richpaddock in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th February 2011, 21:45
  3. multitronic problem setting off
    By leigh a6 in forum General Technical / How To
    Last Post: 12th August 2009, 20:33
  4. A6 TDi Multitronic problems
    By Maggot in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd May 2007, 09:23
  5. MULTITRONIC PROBLEM - HELP
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2004, 10:41
Tags for this Thread
