JMB RetrofitsAH Fabrications
Results 1 to 15 of 15
Thread: Towbar Removal
    AudidriverA4's Avatar
    Sep 2012
    181
    Towbar Removal
    Hi
    My A4 has the a horrible towbar on it
    And has the two light sockets connections which I out after meant that the car was used to tow a caravan
    Could this have done any damage to the car/ clutch or gearbox?
    Anyway I plan on removing it fairly soon
    Is it a job for a 'DIY' mechanic or would I have to take it to a real mechanic to get it removed?
    What exactly is involved, removing the rear bumper? and what about the electrics of cutting the wires and light connections?
    Also I've heard a friend says if you remove a towbar there is some other part you have to fit back on the chassis?
    Big of a long winded post but
    Oct 2009
    Hull
    1,440
    really easy to remove
    pull back the lining in the boot and you will find 3 or 4 10mm nuts for the bumper remover these and pull the bumper
    lift up the floor and look for the 4 bolts holding the towbar remove them and pull it off detach the wiring hopefully its just scotch locks and they come off easy
    yes there is a aluminium bumper bar that goes in its place
    Sep 2012
    181
    Thanks Stu
    I don't have the aluminium bar, would it be important?
    What would happen if I just put the back on the bumper with out the bar?
    It seems like a simple enough job so Think I'll give it a go
    Is the bumper hard to line up when fitting it on ?
    Also you wouldn't happen to know would the towbar off my 2004 B6 A4 fit a 2004 B5.5 passat?
    Jun 2011
    13
    Not sure if A4 cab is the sam, but I bought my car wiithout a towbar but when removing the bumperto fit reverse sensors I found it had been cut out underneath and a towbar had been fitted before I owned it. Anyway the point I am trying to make is that I was glad I removed the bumper as the crossbar that sits under the bumper was missing. It is a crash bar that takes a rear end shunt and transfers the impact enegrgy along the chasis. You need one if it isn't fitted. In the picture below. The crossbar has two square arms that slot into the square holes above the exhausts, in the chasis either side of the car. Bolts then hold it in place down from inside the boot. Bought mine from a chap that was breaking one on ebay. £40 make sue you get hrizontal bar and the two arms and the 4 bolts.
    Oct 2009
    Hull
    1,440
    Re: Towbar Removal
    Yet can't go wrong when lining the bumper up it just slots in to place!
    And as above for the bumper bar you need it really or you could leave the towbar in place and just remove the parts so you can't see it!
    Sep 2012
    181
    Thanks for the replies
    Hoping to give this a go, once I locate the crash beam from a breakers yard
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    most A4 towbars you can just remove the neck of the bar, or attack the towbar with a grinder
    Apr 2012
    N. Wales, LL22
    1,224
    pics
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Sep 2012
    181
    Quote Originally Posted by Ste_Nova View Post
    pics
    Here is the bad boy here
    Still haven't got round to sorting this out yet....
    Jul 2012
    Fife
    17
    Thats the same as my one, i was just going to take the bumper off and cut the bit that the toball is actually mounted to off and leave the crash bar that there. Cant be bothered waiting for a crash bar to turn up!
    Aug 2010
    1,540
    i dont use my towball on my 100. very handy tho when reversing up to walls in car parks tho. best parking sensor ever!
    buy one of these.
    Clarke CON1050 Contractor Angle Grinder - Machine Mart
    bob the bumper off and chop the hitch off as close to the cross bar as you can.
    scott b's Avatar
    1,254
    looking at where the sockets mount that part of the towbar will unbolt, and just push the sockets into the bumper so there out of sight
    Sep 2012
    181
    Quote Originally Posted by scott b View Post
    Yes I spotted that alright, thats actually what I plan to do now, remove the bumper and then just remove the 'neck' of the towbar,
    Maybe the sockets could be pushed up behind the bumper alright, If not I'll follow the wires back to the rear lights and remove the splice clips,
    Just have the towball off for now
    scott b's Avatar
    1,254
    to just remove the neck the bumper can stay on, saves a lot of messing about
    Sep 2012
    181
    Just a quick update to this tread, I have since removed the towbar:
    Looks more like a car now
    However I have since picked up a s line rear bumper would it fit over this?:
    As I don't fancy removing the rest of the towbar, so the new s line bumper would really cover the rest of the towbar and you would never think there was a towbar on it at all in the first place
  1. Removable towbar, bumper cut out alternative?
    By MxGaza33 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2012, 14:01
  2. Removable Towbar Help!
    By Bailey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2009, 13:05
  3. Rear Bumper Removal
    By Jon in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2003, 13:10
  4. Removing key stereo power off
    By mramage in forum In-Car Entertainment
    Last Post: 24th January 2003, 13:46
  5. Rear side panel removal ?
    By vwchico in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2003, 07:43
