AH FabricationsBadger5
Results 1 to 7 of 7
    glenandem's Avatar
    Sep 2012
    manchester
    530
    19 inch wheel offset question!
    im on the lookout for a set of 19s for my a4 avant sport b6 and ive found some that the guy said was fitted to a 2002 passat and theyre the right 5x112 stud but hes told me offset could be 48but hes not sure as it doesnt start with et on the rims,now going off his info if there 48 will they fit ok being 19s and in the arch that much as i believe around 35 is the ideal offset?
    im gonna fit coilovers too and hoping to lower it abit more than the sport height so dont want to rub any suspension components etc!
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Depending what width they are, they will fit. Idealy you would need some 15mm spacers all round.
    Id recomend Creations motorsport for the spacers. There cheap hubcentric and of excellent quality.
    glenandem's Avatar
    Sep 2012
    manchester
    530
    hi pal,there 8x19 rims with 225 35 19 tyres, when you say i'd ideally need 15 mm spacers are you saying that based on cosmetic reasons ie wheels sat too far in arches or are you saying it would need them to avoid rubbing suspension body etc?
    also ive been offered some 19s with 5x114 stud pattern which were fitted to an avant but i'd need to get a set of wobbly bolts,has anyone had any experience with these?
    im not so keen but these rims look really nice on his avant!!!
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    ET 48 will sit in the arches anything from 30 to 35 on an 8" wide wheel would be perfect. My winter 19" RS6's are 8" with et30 and sit perfect with the arches. My bbs LM's are 9.5" at the rear with et35 and have a nice bit of poke. As for wobble bolts I tried them once and found them deadly I would not recommend them
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    glenandem's Avatar
    Sep 2012
    manchester
    530
    yeah i cant see wobble bolts being too clever myself,shame because those rims are 35mm offset and look the best and the other 19s are perfect in every way but 48mm offset but he cant confirm that as its just a couple of numbers he found inside the rim and it didnt start with the letters et so they might be anouther offset for all i know!!
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    what wheels are they?, et 48 will be fine you will just need the spacers to get it to look right,
    Greeny233's Avatar
    Mar 2011
    Llangollen
    703
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    My wheels are 8.5x19 on the front with et42 and 5mm spacers (et37) and 9.5x19 on the rear with et40 and I have plenty of clearance so i think anywhere between et35 to et45 will fit ok.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
  1. Wheel offset question
    By Blackie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd March 2011, 22:31
  2. Quick Wheel Offset Question
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2010, 20:19
  3. Wheel offset question
    By Syncopix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th March 2010, 19:10
  4. 19 INCH WHEEL OFFSETS???????
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2009, 11:39
  5. Wheel Offset Question
    By Hatmeow Sportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2007, 16:19
