EM TuningSky Insurance
Results 1 to 12 of 12
    Jun 2009
    60
    2.5TDI Quattro - Needle lift Sensor (G80)
    Hi all
    VAG-COM is showing the error above, it has actually been there since I bought the car 3 years ago, but I am now on a mission to clear all the error codes as I have a few more now -- notably one regardinng the Water Temp Sender (I have bough a replacement one and will be fiting that along with a boost solenoid N75)
    anyway does anyone know what the part number is for the injector that has the needle lift sensor and if I can get it other than a main dealer
    cheers
    James
    the car is a 2002 2.5TDI Quattro btw
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    I replaced my 3rd injector a few weeks ago - there are a few different variants, your dealer will be able to find out which one you need from your registration.
    Make sure you get two (two per injector) new copper crush washers for the injector leak off pipes.
    Quote Originally Posted by hodgy0_2 View Post
    Hi all
    cheers
    James
    Jun 2009
    60
    thanks Alex
    how much did the dealer charge you? per injector
    Feb 2012
    Liverpool
    1,068
    I went to TPS in Liverpool - ended up at £280 with the VAT
    Was hoping to just leave it as it was, but couldnt time my engine without it working.
    thanks Alex
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    I did this one and i tackled it myself,
    How2: 2.5 TDI Injector replacement.
    Jun 2009
    60
    yep, thanks Turkset and Alex
    I have read those two threads, very useful -- i will try and get this done asap
    tbh I have been living with this error since a bought the car, it did not seem to be causing much of an issue
    and I put the initial boost problems I had with the car down to a cracked front intercooler - what a biatch that was to replace
    Turkster's Avatar
    Dec 2007
    2,713
    From my experiance, the only real differance is the MPG, I found i was loseing about 5mpg with this error code, since the change over my car has run smoother and has a slight incress in poke, the mpg have most prob gone up too but my lead foot has an illness,
    Jul 2007
    765
    Made little diff to mine.Probably slightly better mpg but not much for best part of £400 for parts and labour
    Jun 2009
    60
    mmm, well I am due to replace the boost solonoid and temp sensor, both show as erroring in Vag-Com
    I might take a view on the Injector
    Turkster's Avatar
    Dec 2007
    2,713
    try ebay for a 2nd hand injector,
    Jun 2009
    60
    Yep, that's what thought
    It looks like I will need the exact part no from a dealer
    Turkster's Avatar
    Dec 2007
    2,713
    well yes and no, i got a 2nd hand injector from ebay with the same part number but the letter on the end was wrong, it turned out that the part number on the end was in reff to the injector nipple hole size, so i swapped over the nipple from my old injector to the newer injector and all was fine,
  1. 00542 Needle lift sensor (G80)
    By dan1 in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th February 2012, 08:48
  2. 00542 Needle lift sensor (G80)
    By HerefordQuattro in forum Diesel forum
    Last Post: 1st March 2011, 13:24
  3. 2.5TDI needle lift sensor
    By Mike B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th November 2010, 12:32
  4. Needle Lift Sensor G80 plus a few other fault codes
    By vrbob in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2010, 13:52
  5. HELP-00542 G80 needle lift sensor error code
    By sebhar70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th January 2010, 16:29
