EM TuningSky Insurance
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    Petrol flap lock motor
    Hi guys n gals....
    My petrol flap lock mechanism has snapped off at the joint between the metal rod and plastic on the mechanism. I've sourced a new part and intend fitting it next weekend.
    Is there an easy way to remove the mechanism as it looked as though the fixings were awkward to get at?
    i may be wrong, but if someone can give me a quick guide I'd really appreciate it..
    TIA,
    Alan
    Alan H's Avatar
    Aug 2010
    453
    Hasn't anyone had to change one of these?
    Alan H's Avatar
    Aug 2010
    453
    OK guys. Quite a simple job only took 15 minutes and that was with stripping and refitting all the boot trim too....
    The petrol flap lock motor fixings just need twisting with a pair of pliers as though you are going to tighten them up (they are only nipped up anyway so no excessive force is required). This undoes the screws and the lock mechanism will slide off.
    Fitment of the new part is the same as removal only in reverse... (As the Haynes manual says)
    I hope this helps someone in the future...
  1. front locking motor
    By audia403 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd August 2011, 22:37
  2. fuel filler flap lock stopped working - anyone else had this?
    By M7R in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th May 2010, 14:43
  3. Help, central locking motor
    By Mpathe in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2009, 22:47
  4. Petrol flap not locking
    By gadgesxi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st October 2009, 13:03
  5. Part request - Small plastic piece on petrol flap
    By technics100 in forum Parts Requests
    Last Post: 5th August 2009, 21:29
