Results 1 to 7 of 7
    Rays18's Avatar
    East Tattoo
    Feb 2009
    N.Ireland
    41
    Remapping a 100bhp 1.9TDI
    Would you even bother?
    Would you even feel the extra 30/40bhp?
    Im in 2 minds weather or not to go for it.
    Thanks !!
    Oct 2009
    Hull
    1,433
    forget the bhp whats the torque figures?
    you drive on torque you race on bhp you will have more use of higher torque figures
    you will notice the difference but it wont be huge
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Go for it !!!
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Oct 2012
    BUMP! I am too looking to do this. Change the air filter and remap. The quote ive had is
    Power Stock Phase One Phase Two
    BHP 100 135-140 140-150
    Torque ft/lb 175 220-225 225-235
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,910
    Do it.
    GNJ_Motorsport's Avatar
    Jun 2011
    Lancashire, England
    618
    Definitely worth it.
    Shark Performance Lancashire Dealer
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,578
    rays - are you okay about replacing your clutch?
    if not, then please check on the specs of your clutch and the max torque it can handle as I think the lower spec TDI engines had MUCH lower spec clutches...
    the TDI remaps are all about mapping in a LOT more low-rev torque and bit more torque further up the rev range, so even if the peak bhp "only" goes up by 25%, the car will feel even faster than that because you will probably get 40% more torque at low revs... just bear in mind that when they made the lower spec TDI models, the engines are still pretty bullet-proof, but they cut back other components (intercoolers, turbos, clutches). The single intercooler is probably fine, the turbo, if healthy now, should handle a remap easilly, but the clutch is usually the weak point and Audi spec the components according to the max torque that they expect the clutch to need to handle on a factory map...
    I'm not sure about the 100bhp in the A4, but I've seen a nearly new 105bhp Polo remapped to 150bhp and the turbo + engine were FINE: but due to the lower spec clutch and the car was utterly undriveable (the clutch with <10k miles on it was slipping even on the rolling road)...
    I know the TDI130's clutch is normally able to cope - seen several those remapped to 175bhp+ without any adverse impact, if driven carefully, but I'd be wary if you're not certain the clutch it up to it - at least get it done somewhere where they will Rolling Road and they should be able to pick up even the slightest clutch slip... the Chip'N'Spin RR days as attended by a few forum members in the past (£250 for 2x RR runs + remap) will advise if they pick up any clutch slip and they'll let you test drive it too and map it down slightly if the clutch can't cope.
    LostBok/BahnStormer77
  1. Would I be silly? Remap for 113k 1.9TDi QS
    By Jimmeh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th August 2010, 17:45
  2. A4 1.9TDI 100bhp booked in on 13th at Jabbasport for remap
    By JGrant1285 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd July 2007, 17:09
  3. 1.9tdi (130) sport stage 1 remap AMD
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st February 2007, 00:03
  4. 1.9TDI Quattro Sport Remap
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2006, 13:50
  5. APR chip or Revo remap for A4 1.9tdi? Which one?
    By oneniner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th November 2004, 20:56
