Volks AutosChris Nott
Results 1 to 7 of 7
    Jun 2011
    130
    Strange/worrying noise
    Hi all just noticed a strange sort of chirpy whuring noise on idle near the serpentine belt area, rev engine a bit and it goes, its fairly faint but annoying ! it seems to make noise on turning cylce
    any ideas ?
    cheers
    Mar 2008
    1,017
    could be a bearing on its way out ..try some wd40
    Jun 2011
    130
    Cheers, stupid question but, where am i spraying !!!
    Mar 2008
    1,017
    on the pully your hearding the sound from
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    spray where you hear the noise
    Jun 2011
    130
    ok, ill have a squirt about, noise has just appeared after the whack i had on the front, hoping its not timing belt related !
    Mar 2008
    1,017
    dont put any wd40 on your timing belt..... just do the pulleys at the front of engine
  1. S3 - Strange brake noise
    By ved789 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th July 2007, 23:49
  2. Strange S3 noise from engine
    By showyS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2007, 08:09
  3. strange whirring noise coming from drivers side front wheel
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th March 2007, 23:37
  4. strange exhaust noise - anoyone had it before ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2006, 09:52
  5. Strange "cluncking" noise coming from front
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 13:10
