Sky InsuranceBadger5
Like Tree1Likes
  • 1 Post By pgull
Thread: 3.0 Quattro Gearbox/Diff noise
    Sep 2012
    Hi there,
    I have a 3 litre quattro sport avant with an increasingly worrying rumble. Its a low frequency grumble when under load that isn't related to wheel speed or revs.
    It started in 5th and 6th gears but is now throughout the box but it only seems to be once the car is warm.
    It doesn't seem to affect performance but its loud enough that you lift off at about 4000 rpm so I havent been brave enough to try to drive through it!
    Its definately at the front end and not the prop bearing noise that some people have suggested.
    Any ideas???
    Sep 2012
    Gearbox and diff oil change solved the problem, just in case anyone was wondering!
    Audi Doodah likes this.
    Mar 2011
    Truro, Cornwall
    62
    Thanks for the update. I'm getting a slight rumble but not too bad. Wheel bearings have been given the ok. This Was my next guess. Will get it changed soon. X x did you do it yourself.
    Sep 2012
    No I was due a service anyway so I just had it all done at the same time. It was only about £50 extra including the oil.
  1. quattro gearbox and diff oils
    By Matt82 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th September 2009, 22:01
  2. A4 Quattro Rear Diff Seals
    By kipps in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2005, 18:50
  3. A3 Quattro Rear Diff/Haldex Coupling Oil Change
    By imported_rob911 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 10:50
  4. A4 Diesel Quattro gearbox oil
    By QuattroChap in forum Diesel forum
    Last Post: 8th June 2004, 21:17
  5. A4 Quattro Gearbox problems
    By pf9911 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th May 2004, 20:03
