EM TuningVolks Autos
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    That's enough hot air for you..
    Hi, now the weather is colder, I'm noticing the following behaviour from the Climate control in my Cabriolet.
    I have a 1.5hr commute (lucky me) mostly A roads and motorway.
    I start my journey and the Climate gets nice a toasty.. all is well until an hour into my drive, I start to get cold air through the vents - it's almost as if it's decided I've had enough heat and it wants to cool me down.
    I can get heat again if i turn up the climate a couple of degrees, this lasts for 5-10 minutes then it starts blowing cold again. if I turn it up a bit more, I get my heat back for another 5-10 minutes etc..
    I've hooked up my laptop and VCDS and checked for any fault codes - none found.
    I suppose the next thing is to take off the glovebox and check all the flap motors?
    Cheers,
    Jason.
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Are you sure it's not just the car starting to pump some cool air in to stop the cabin temperature rising above the programmed temperature?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,257
    sounds to me like its achieving the desired temp on the front of the climate and then its maintaining it. you get hot air again because your asking the unit to heat the cabin to a higher temp once there it then cools the output temp as it doesnt need to heat it anymore. The unit has a built i cabin temp sensor.
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    621
    I agree with the other two and I suspect you're only saying 'cold' air from the vents as you're used to being toasty, so ambient air will feel cool. I have this issue to, it's annoying. You could put the temp onto max and manually adjust the fan speed to 2-3 bars to keep it warm, but not getting the cabin too hot.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    Thanks for the responses, I shall hold off removing the glovebox for now.
    this is my 5th Audi with climate.. I must just be used to how the others behaved..
    I'm pretty sure those would get up to temp, then back off the fan to the lowest setting, so I wouldn't notice any cold air mixing in.
    Previous Audis:
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    VagCabby's Avatar
    Apr 2012
    Crawley, West Sussex
    218
    My cab does this and I have just assumed its the cabin getting hotter than what I have set it to so its pumping the cold air in, all I do if I want it warm is to set the temp with econ switch on to shut the a/c off
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
  1. S3 not low enough at front for you?
    By Khufu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2009, 18:55
  2. Heel & Toe : a pain for you too?
    By JaminBen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2005, 13:34
  3. Replies: 8
    Last Post: 13th February 2005, 17:09
  4. A Couple of videos for you :o)
    By dakiller in forum Classic Audi Forum
    Last Post: 13th April 2004, 11:42
