Chris NottVolks Autos
Thread: Polybushing
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Polybushing
    Just interested to see if anyone has done any polybusing on the B6 A4?
    I have a 2.5 Quattro Avant - the front has started knocking slightly - instead of replacing the arms.etc - I am wanting to polybush to stiffen things up a little.
    Only problem is - I cant find any items out there for the B6 Quattro - all powerflex list are items for the B5 models.
    Would items from the B5 / Passat B5 fit the upper suspension arms / anti roll bar.etc?
    Many thanks!
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    I have the same car and last year mine was knocking the same so i replaced some of the bushes but with standard ones. From the research i did i can give you the part numbers i found for the standard bushes but you should be able to compare these on the polybush website,
    top rear arm 4BO 407 515
    Top front arm 4BO 407 515
    Bottom (curved) rear arm 4DO 407 183 AB
    Bottom front arm bush that connects to the car 4DO 407 182G
    Bottom front arm bush that connects to shocker 8EO 407 181C
    I must say though that these did not cure the knocking as it is the ball joints on the ends that seem to do the knocking, however stiffer bushes may resist the turning forces and stop the ball joint from rotating. Its a gamble good luck
    Oct 2008
    Glasgow
    430
    I wouldnt recommend poly bushing the old arms. The bushes may be worn but the chances are the ball joints will be as well.
    The bushes for the upper arms are the exact same for the b5/b6/b7 as are the curved rear lower arms. The front lower arms have a different ball joint from b5 to b6/b7 due to the uprights being different, i also think the bush that the strut attaches to is thinner on the b6/b7 than that of the b5.
    brasiliangringo's Avatar
    Mar 2010
    496
    Exactly, give you an example: i replaced two front ARBs on a car recently and one drop link (as gaiter split) but decided not to replace other original side link = i had a huge knocking that wasnt there before as now the rest of the set up tighter, that slack and wear in the original was now amplified and KOCKED like bugger when it never did before. Good lesson though.
  1. Audi S3 Polybushes
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2010, 19:49
  2. Polybushes
    By Bula_82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2007, 18:38
  3. polybush kit for sale
    By cg in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2007, 16:48
  4. 1000 mile polybush and coilover test
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th April 2007, 22:06
  5. Reasons NOT to fit polybushes to A3 rear axles.
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2006, 13:39
