Chris NottMonster Motorsport
Results 1 to 10 of 10
    Oct 2011
    Harrogate, North Yorkshire, United Kingdom
    11
    A4 1.9tdi Q avant
    Right lets see what you all think of this little problem i have, scanned with vcds 2 faults temp sensorand engine mount,fitted new temp sensor with genuine, engine mount purchased but forgot to bring it home.right im having issues with misiing or holding back when im going up the rev range under load first miss at 1700 then 2300 then about 4300 the car drives really nice but when you want to get on it holds back, disconnected maf no power, ive been out with vcds plugged in everything seems ok can anyone shed any light on this for me thanks
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    It could be the turbo vains putting the car in limp mode.....other than that check the obvious boost pipes etc
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    pauldazzle's Avatar
    Cardiff
    620
    Could still be the MAF as the unplug it to see if it runs better trick doesn't seem to work on Audi TDi's.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Oct 2011
    11
    Im going to try fuel filter on monday its not been changed since october 2011.
    Oct 2011
    11
    Im going to try a maf tomorrow my tdi golf has same maf that will save buying one if its not that
    Oct 2011
    11
    New maf better at 2000 revs still juddering at 3500- 4000 revs ,going to clean egr,and then see what else i can try!
    Oct 2011
    11
    Hi all ive still not managed to cure this fault,replaced thermostat its now worse and only does it once the car is up to temp, ive had the egr deleted via the ecu so thats now not a issue but would i still need to clean the egr valve out ??? Any help would be great many thanks
    Oct 2011
    11
    Hi all egr cleaned today and blanked off it wasnt that dirty tho, turbo cleaned too actuator arm is free but i still have same problem someone must have a clue what is going on,going out with vcds tommorow to see if it puts a fault up hey ho
    Jul 2007
    London
    3,209
    Take the rocker cover off and look closely at the camshaft, pay attention to the lobes pushing on the lifters ! I bet a few are worn..
    FOR SALE:
    Oct 2011
    11
    Yea good point but only has the symptoms when warm !!!
  1. New to Forum. Suspension Advice on our Audi 1.9tdi SE130 Avant.
    By Ianb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th January 2012, 21:59
  2. Can't find the right 1.9tdi 130bhp Avant Sport
    By p1tse in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th April 2011, 21:11
  3. Cambelt Change... When is it due on my 1.9tdi A4 Avant?
    By col004 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th March 2011, 21:45
  4. Will these wheels fit my A4 B6 1.9tdi sport avant
    By patch20v in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th February 2008, 14:35
  5. Replacing engine mountings on '96 A4 1.9tdi Quattro Avant
    By chuffy in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2006, 15:26
