AH FabricationsVolks Autos
Results 1 to 8 of 8
    Sep 2012
    6
    Exclamation limp mode intake manifold pressure exceeded intermittant
    Hi I recently brought a 2003 A4 convertible 2.5TDI and have a limp mode problem so far maf and map sensors changed plus valve on bulkhead (dont know what its called) mr muscle to the turbo twice particulte filter cleaner put through the system and cat cleaner every one of these items have made improvements but I seem to be skirting around the fault (0575) running out of ideas can anyone help
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    hi there
    this is he ross tech wiki for that fault code 00575 - Ross-Tech Wiki
    you have already done the n75 valve by the sound of it (the bulkhead one) have you checked all of the hoses?
    Sep 2012
    6
    rgr that changed that I am wondering if improvement after Mr muscle used are not from turbo but has had a slight cleaning effect on either cat or particulte filter ??
    Sep 2012
    6
    by the way other causes of 0575 can be blocked particulate filter/ blocked cat its a shame vagcom seems to be such a basic diagnostic system very basic and cannot properly fault find and as I found out to my cost with BMW main dealership for my Z3 they have "technitions" not mechanics if the plugged in diagnostics does not lead them to the fault by the hand they are clueless.(rant over)lol
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,413
    I had this on the wifes Mk5 Golf. It was the joint cracked of the exhaust gas sensor to the manifold. Couple of tack welds and sealed it up and has been fine ever since.
    Mike
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    This pops up on mine whenever I scan, I put it down to the re-map I have on the car - im guessing the turbo is giving more pressure so its outside standard tolerances and throwing up a code?
    Sep 2012
    6
    Hi today I gave it the full Basil Faulty gave it a dam good thrashing major improvement thinking this has blown some of the build up in the cat/particulate filter after the additives have been through the system will retreat with cleaner and Basil it again I will report outcome in a few days Rock
    Sep 2012
    6
    Hi well so far so good took the Audi out for a run (pi##### with rain the problem seems to be cured hopefully.
  1. Replies: 45
    Last Post: 15th August 2012, 13:12
  2. A6 2.5 TDI 00575 Inlet manifold pressure exceeded
    By devine0969 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th February 2011, 18:36
  3. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
  4. Going Into Limp Mode
    By johnboy1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2004, 17:55
  5. N75J and limp mode (overboost problems)
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2004, 18:52
