Monster MotorsportBadger5
    Sep 2006
    27
    Black smoking and noisy acceleration
    Hi all,
    I have a tdi sport 130 saloon. The other day I was informed by the old man, that when he was following me, i was chucking out a bit of black smoke under acceleration. Also i have noticed that it is quite noisy under acceleration or downshifting (i.e. it bellows a bit). This is my first diesel i have owned so I'm not sure whether the noise is normal or not, but I'm pretty sure it shouldnt really be black smoking.
    The car has done 89k miles, and is completely standard (as best to my knowledge). Would a egr blank and inlet manifold clean sort the smoking out? or am i looking for split boost/intake hoses causing the smoking and the noise?
    Many thanks
    Jay
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    I'd defo start at boost pipes theses are prown for boost leaks louder noise and bellows of smoke.....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Sep 2006
    27
    Quote Originally Posted by marktdisport View Post
    ok cool cheers. whats best way to go about this? engine running and trace all the hoses till i hear one leaking or is there an easier way i.e. spray hoses with fairy liquid solution and watch for bubbles??
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,566
    I would check the upper hoses are secure and solid with no cracks etc then jack the front end and remove the under tray to check the inter cooler and lower hoses.
    I had a boost leak and it was the hose coming up from inter cooler joint near the fuel filter had come away. Put back together with a new clip and no smoke or power issues since.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,566
    Don't add liquids to the hoses as the system is under pressure and will be sucking air in not blowing it out.....more so when the turbo is spinning, and you don't want water etc sucked into the engine.
    Mike
    - BUILD THREAD >>
  1. Audi A3 1.9 2005 Sportback EM light and Black smoke
    By Shahid Faqir in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2011, 12:28
  2. Help, S3 missfire and black smoke between 3000 rpm and 3750 rpm
    By sportquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2011, 16:56
  3. Limp mode and black smoke
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 21:41
  4. Intermitent black smoke and boost after new turbo fitted!
    By MAD WELSH JIMMY in forum Diesel forum
    Last Post: 26th September 2009, 23:55
  5. A4 2.0 TDi and a lot of black smoke!
    By S30AN M in forum Diesel forum
    Last Post: 11th January 2009, 14:52
