EM TuningChris Nott
    audi a4 chrissy
    Oct 2011
    County Durham
    19
    HELP!! my audi A4 1.9 TDI awx 130 timing belt has ripped teath off and won't fire :(
    Would apprietaite your help if you can very much! I am thinking of replacein in the top end only do you think it will be worth while? i have been told these engines arent likely for the bottom end to bhave gone with it!
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    was the belt intact still, apart from ripping teeth off it. Has if deffo done the head in, it wont fire probably because its well out of timing.
    Jul 2007
    London
    3,072
    Don't crank it anymore, you will bend the rest of the valves you have not bent already ! Take the rocker cover off and see how many lifters are broken- you will require to take the camshaft off first ! If no visible damage then get a new belt and time it acordingly then spin the engine by hand and make sure the marks align and you KNOW what you're doing !
    FOR SALE:
    audi a4 chrissy
    Oct 2011
    County Durham
    19
    Thanks guys! yess the belt was still in tact just a few teeth missing i am going to have it looked at to see what the damage is! any recommendation's for tunining while its apart?
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    Do as Adam says...... you might be lucky, it's dosn't take much movement in the timing for these engines not to fire
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
  1. Help please - Audi A3 2.0 TDi - alarm problem!
    By hotfuss73 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2013, 20:09
  2. Urgent help needed, Audi a3 2.0 tdi sline 2004
    By cheeco in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2012, 23:18
  3. Urgent help needed, Audi a3 2.0 tdi sline 2004
    Last Post: 31st July 2012, 12:35
  4. audi a6 1.9 tdi diesel 130 sport avant
    By hoddy8770 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2011, 19:55
  5. audi a6 1.9 tdi diesel 130 sport avant
    Last Post: 10th March 2011, 13:49
