AH FabricationsSky Insurance
Results 1 to 10 of 10
    AudidriverA4's Avatar
    Sep 2012
    179
    A4 starting problem - Intermittent
    Hi there
    I'm just having problems with my 2004 130 (avf) bhp B6 A4
    Some times when I go to start to start the car, the glow plugs will not show on the dash and the car will not start, it just keeps turning and turning,
    However if I leave the ignition switched on (the same as if you were waiting for the glow plugs to go out) and wait anything from 1 to 10 minutes all of a sudden the glow plugs will appear and then the car will start and is driving perfectly
    I got a video of it here one time it happened to me:
    Audi A4 starting problem - YouTube
    I have since taking the car to a mechanic to works in a VW garage, he looked at the car and reckons that the car needs new clocks, and the only way to get this done is through an Audi dealer ship which at the moment is looking like it is going to cost a bomb, and this problem is intermittent so it might happen one start in every 30 so I'm not sure what to do with the car,
    from doing some googling it looks like it is a simple Relay 109 problem the car has:
    owho is right?
    Is it worth changing the relay before bring to the Audi dealership?
    Also how hard would it be to change this relay?
    Thanks in advance I know this wasa long read
    Jun 2012
    Teesside
    390
    Im not 100% with the audis but i know with my old golf it was possible to buy a full ecu clock and lock set from a donor car just try and get the skc code from the old ecu,
    Im pretty sure aslong as you have the skc any clocks out of same car could be coded just the mileage would be wrong? im sure one of the more experienced users will correct me if im wrong
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    kite's Avatar
    Oct 2007
    East Berks
    659
    Re: A4 starting problem - Intermittent
    Changing the relay is cheaper than replacing the dashpod.
    If it is a dash fault, there are Co's that repair them.
    A4 (b6) 2.5 TDi QS Saloon.
    Sep 2012
    179
    Thanks for the quick replies
    Yes when I found out this I was in to minds weather to sell on the car or spend 1000+ on it, he said it also needs a new ABS module
    I think I'll give try and change the relay 109 first it's worth a shot anyway,
    Does anyone have a link to How to change this Relay?
    Thanks again
    kite's Avatar
    Oct 2007
    East Berks
    659
    Google brings a few answers up.
    Sep 2012
    179
    Just to update this,
    I noticed when the glow plugs are not showing the 3 brakes lights at the back are showing, even though I don't have my foot on the brakes
    It would hardly have anything to do with the brake switch would it ?
    Oct 2009
    Hull
    1,433
    Quote Originally Posted by AudidriverA4 View Post
    stranger things have happened at sea!!
    has it been scanned for fault codes? if so what came up?
    Sep 2012
    179
    Quote Originally Posted by stu_m View Post
    Yes it was scanned and no faults came up
    The car has since 'died' it now won't show the glow plugs at all now
    So that's the end of it starting now
    Oct 2009
    Hull
    1,433
    I would check out the glow plug relay first
    Sep 2012
    179
    Thanks Stu
    You wouldn't happen to know where it is located or what number it is ?
  1. Audi A6 Estate 2.5TDI 2000reg intermittent start problems
    By Khi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th July 2010, 13:31
  2. intermittent starting problem
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th November 2007, 17:53
  3. Intermittent start Problem and Air con gas.
    By imported_Astwell in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2004, 20:23
  4. a4 starting problems
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2004, 12:44
  5. 2.5TDi Starting Problems
    By aj_mackay1 in forum General Technical / How To
    Last Post: 22nd April 2004, 12:28
