EM TuningJMB Retrofits
Results 1 to 10 of 10
    Aug 2012
    Medway, Kent
    162
    Dropped drivers and passenger side doors
    Thought I had posted about this but can't find it. Both the drivers and passenger side doors have dropped. Drivers side is worse, catches on the wing and have removed paint etc so want to get this sorted ASAP.
    I have seen numerous posts on this, but not sure on how to fix it - is there a guide on the bolts etc that needs adjusting and how to get to them?
    Thanks!
    Mar 2008
    1,053
    What car is it ???
    Aug 2012
    Medway, Kent
    162
    Quote Originally Posted by vr6gordy View Post
    What car is it ???
    Sorry, thought I'd posted that but obviously not!
    It's a B6 A4 1.9 130 Saloon.
    Mar 2008
    1,053
    any pics of the shut lines ????????????? what are the gaps like on the lock side of the door ?????
    simon.m's Avatar
    Oct 2009
    2,746
    you can adjust the doors by slackening the bolts of a bit its guess work so you have put it how you think it should be nip the bolts up and then shut the door and see how it lines up it will take a few goes to get it right. this should do it i no where the lock part is you can see lines to give you a guide line
    Aug 2012
    Medway, Kent
    162
    Thank you - I'll get some pics tomorrow.
    Aug 2012
    Medway, Kent
    162
    Finally managed to get some pics;
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    WOW that really has dropped loads. You sure nothing is broken in terms of hinge.........looks like the lower one with the issue to me.
    When you open the door do any hinges move?
    On previous dubs I have worked on the nuts are located in the door.......so door card off and arm down the inside but not done one on an A4
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    ELSAWIN, a Haynes manual or ETKA for a break down should help
    Mike
    - BUILD THREAD >>
    Aug 2012
    Medway, Kent
    162
    Quote Originally Posted by mjmallia View Post
    Can't see anything obvious. The doors are the next thing on the list after clutch and DMF so will let you know what the outcome is
  1. Window Problem - Both driver and passenger side!!!!
    By s.timbers in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2012, 11:30
  2. AUDI A6 C6 BOOTLID AND INTERIOR PASSENGER SIDE DOOR STRIPS
    By Yaseen1991 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 2nd March 2012, 09:23
  3. Passenger side door....
    By Sanj in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2010, 16:42
  4. passenger side door trim
    By twofivenine in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2007, 22:07
  5. Passenger side door
    By a3daveo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2007, 23:55
