Monster MotorsportBadger5
Results 1 to 9 of 9
Thread: High revs
    Aug 2012
    Medway, Kent
    162
    High revs
    Hi all,
    Over the weekend when I started the car, the revs went up to around 1500 for about 2 seconds then went down to under 1k revs where it normally is.
    Have been off sick most of this week so not used my car, but when using it this morning I was driving along and when taking my foot off the accelerator the revs would stay where it was, say 2.5k or 3k revs for about 2 or 3 seconds then it would drop in a chunk and go down as it normally would, so the speed stays at what it was then all of a sudden after a few seconds it decelerates as expected. Really weird feeling, and never had it before - anyone got any ideas?
    I've got a A4 1.9tdi 130 Sport Quattro.
    Thanks!
    warren_S5's Avatar
    Oct 2007
    7,163
    Coolant temperature sender?
    Aug 2012
    Medway, Kent
    162
    Quote Originally Posted by warren_S3 View Post
    Would this log a code that I can read?
    warren_S5's Avatar
    Oct 2007
    7,163
    Should do.
    I've read it on a couple of other forums:
    Honest John (Audi A4 1.9TDi revving and idle issue | Technical matters | Back Room Forum | Honest John)
    Audi World (1.9 tdi revs too high)
    Hopefully it will be that and nothing more expensive .
    Aug 2012
    Medway, Kent
    162
    Should do.
    Is this the same sensor that you replace when the car reads the temp as between 50 and 90, but never at 90?
    warren_S5's Avatar
    Oct 2007
    7,163
    I believe it is yes. Why, has it been changed recently?
    Aug 2012
    Medway, Kent
    162
    Not yet, but I have new sensors sitting at home waiting to be fitted
    warren_S5's Avatar
    Oct 2007
    7,163
    Good good, hopefully that will cure you issues! If not you'll be flexing the wallet and looking deeper into the engine bay!
    Aug 2012
    Medway, Kent
    162
    Thank you for your help - hopefully that'll cure it.
  1. S3 turbo kick, high revs
    By AL_B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2007, 13:41
  2. S4 white exhaust smoke only at high revs
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th June 2007, 20:41
  3. Annoying High Revs!!
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th April 2007, 22:27
  4. noise at high revs??
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2006, 17:29
  5. Power loss at high revs
    By imported_alecblack in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2006, 12:39
