Sky InsuranceChris Nott
Results 1 to 13 of 13
    Sep 2009
    Rumburgh Suffolk
    192
    heated mirrors retrofit...
    I'm thinking about the heated mirror retrofit again, I did a while back, but then my little girl arrived and things kinda took a back seat..
    Heated mirrors..
    Cheers again for all the replys, I'm on the verge of buying a couple of genuine heated mirrors from the local stealer, in the mean time I'll try and check meas blocks 12 & 13 in 46 central conv module and see what their status is in there, as Woorlord done in the above thread.
    If anyone has any more info or experience on retrofitting them I'd be glad to hear it.....
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    i bought two and fitted them and they worked straight away with no coding needed, i have spoke to a few people and they all said the same. only thing i had to do was clean up the connectors as they had been sat corroding for a few years. I bought a left hand drive drivers mirror for my passenger side as this has the blind spot as our drivers has.
    Sep 2009
    Rumburgh Suffolk
    192
    I spoke to the local stealer yesterday, and from the reg number he says it should have heated mirrors, so maybe they have been broken and replaced.. I dont know.
    Anyway, I've heard of people buying aftermarket mirrors, to find they wont work, then fit a genuine one and alls fine.
    Does it have to be genuine ones, and genuine prices, or is there an aftermarket one that will work??
    Mark
    Lancaster
    1,780
    I bought aftermarket ones and they worked great.
    To do: None yet.
    Sep 2009
    Rumburgh Suffolk
    192
    In the manual it says the mirrors will heat up when the rear demist is switched on and the ambient air temp is below a "certain" temperature..
    Anyone got an idea of what this "certain" temp is, I fitted a new heated mirror earlier and it didnt warm up, but the DIS was showing 20 degC..
    Mark
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    From memory its 7c.
    Sep 2009
    Rumburgh Suffolk
    192
    Fired up this morning, and it heated up, DIS showing 13deg, very damp..
    While were on the subject of temperature, anyone noticed the bug in the DIS regarding the ice warning symbol?
    Mine comes on at 5deg, and then stays on as the temp drops, until -5.5deg, then it goes out again, on our 2004 at work they had changed it.. maybe Audi presumed at first that at that temp you need to be a muppet to not realise theres ice about..
    Mark
    Sep 2009
    Rumburgh Suffolk
    192
    Just to add to the end of this thread, the drivers side would never heat up.. got round to checking it out and it turned out that the two heater connections on the door control module were both corroded, cleaned and alls fine..
    so if anyone does try this mod and it doesn't seem to work, whip off the door trim and check all the connections..
    Mark
    T0m
    Sep 2007
    Lichfield
    458
    Talking of these heated mirrors mine has got them and when the one got damaged by a lorry I had to take it apart and there is another loose spare wire in my housing with a connector on it but it wasnt connected to anything does anyone know what this is for?
    I will try and get some pics when its try as its covered in tape at the mo to keep it all dry!
    Oct 2009
    Hull
    1,440
    so you have 3 wires?
    T0m
    Sep 2007
    Lichfield
    458
    Yup the two for the heated element and then another wire with a connector block for something else.....only thing I can think of is auto dimming mirrors maybe?
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    Am I right In reading that they are all pre wired but just not fitted ??
    I still find it strange that they didn't fit them as standard !
    I can't find a fuse so I assumed it doesn't have one , mirrors coming off tomorrow and am checking if it had wires and heating elements !
    I bought a convertable in the wettest country in the world who says Scotsmen dont have a sense of humour !
    "Lets fire up the Quattro" DCI Gene hunt,,,,,,,ashes to ashes
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    1,836
    Its official Audi are cheap barstewards a 30k motor when new and i pulled the mirror off two wires and no where to plug them into !
    going to have to get a heated set , esp with winter here .
  1. Heated mirror retrofit
    By jsh in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th February 2010, 09:21
  2. Heated Mirrors stopped working - AGAIN!
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2004, 22:08
  3. Heated Mirrors (Retro fitting)
    By nhenty in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th February 2004, 22:08
  4. Heated Mirror Problem??
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2003, 10:24
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
