Monster MotorsportEM Tuning
    S23
    S23's Avatar
    May 2012
    Torbay
    139
    Add S23 on Facebook Visit S23's Instagram Channel
    Quality of ride feels weird ??? Or am I just paranoid
    I recently purchased some new wheels I upgraded from 17" to 18 " 3sdm 0.05 they are 8.5j on the front and 9.5j rears I had to also add some 20mm spacers to the tears to stop the wheels from catching , the fronts are not spaced . The first week they seemed fine now it seems a bit shakey and cornering dosent feel right I just can't put my finger on it , it's running standard suspension and got 225/45/18 tyres all round the rears have abit of stretch . My thoughts were should I space the front by 20mm also so its the same as the rears ? Can anyone offer any advice ?
    Scott
    Mar 2008
    1,058
    I had this with my old a4 when I spaced the rear ...what I found to do crack the wheel nuts then jack car up the tightened bolts up going opposite nuts so you centre the wheel the let car down of jack and tightens the same way
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,582
    You sure the spacers are sitting flush to the hub all the way round as have bought some in the past that look like they are but about 1mm off.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I don't think adding spacers to the front would make any difference, why would it?
    20mm spacers are pretty wide, I'd guess that's your problem. What make are they?
    Mar 2008
    1,058
    What size wheel bolts you using plus do they sit in the nut cup ok
    S23
    S23's Avatar
    May 2012
    Torbay
    139
    The rear bolts are 50mm and go through the spacers and into the hub there not the ones with 10 holes , could that be a problem ? If I got different spacers so it would have standard sized bolts into the spacer and a seperate set into the hub , or does it not make a difference
  1. Car feels weird at motorway speeds
    By Bong Water in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th January 2008, 17:39
  2. Ride quality......
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th March 2006, 20:43
  3. Weird driving feeling...
    By Lynas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th February 2006, 07:36
  4. ABS light on when 70mph reached!! Pedal feels weird
    By craggy_t in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2006, 19:27
  5. Is the ride quality any better with 17s?
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2005, 23:22
