It might sort of work....will my rns-e need coding or is it just plug and play .. i have the plug and play loom so is it just a case of swoping head units ???
So it should turn on/off with the ignition then.it came out of an a4 and is going in my a4 cab
Witch side of skipton ?? This side near me or the far sideI'm 30 mins from Skipton if you get stuck.
You need to change adaptation channel 62 of the Instruments (address 17).what name is it under to change code soi see arrow on dash when i use sat nav
