I keep getting code 17669 injector 1 regulation range exceeded.
Ross Tech says check injector & injector wiring so I replaced the injector loom/harness last week & all was fine for a few days but the code has now come back again. Traction Control light comes on & the car shakes when around 1800rpm. Cycling the ignition removes the TC warning light & the shaking stops, but after a couple more driving cycles the TC warning light comes back on & the EML.
I did some logging tonight & in measuring block 023 injector 1 is reading 127 pretty much most of the time. Is this confirming that injector 1 is faulty?
BTW logs were done without my Van Aaken Smartbox plugged in so it's nothing to do with that.
