Chris NottEM Tuning
Results 1 to 20 of 20
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    Add GeoffDunk on Facebook
    Lightbulb S4 won't start, please advise?
    Hi all, I am suffering a repeat problem with my 90k mile 2004 S4, can anyone help?
    After a long trip home at the end of the week I stop the car and leave it in the driveway, the next morning I go out to start it and it won't start. I have tried the following but can not find a consistant fix.
    1. New battery in key fob ( battery not neaded for mobiliser deactivation)
    2. Using 2nd key (also with new battery), seemed to work once.
    3. Long journy leaves the tank with 10 miles of fuel in it so I put in 5 litres from a can at home and this seemed to help start it but I cant believe its the problem, unless AUdi in thier wisdom won't allow you to start a vehicle with low fuel? My 200k Passat TDI and A4 Avant never had this issue and I reg run them to zero. this has work twice.
    4. Thinking it s a fuel pressure problem I have tried releasing pressure by removing fuel filler cap.
    Nothing above seems to be a garunteed fix but it does start eventually after about 30 mins allthough the fuel top up seems to help but I think its purely coincedental.
    Has anyone else found this problem, if so what could be causing this. So far its only happpened in my driveway but I work over 200 miles from home and can only imagine what would happen if it occured soemwhere else.
    Look forward to anyones thoughts on this?
    Geoff
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Is the car being parked on the level ?? Running the car that low ain't doing anybody any favours m8
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Jun 2011
    Great Melton Norfolk
    1,344
    if you want it scanned i am in Chedgrave .
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    Running the car that low should not make any difference, I spoke to an independant specialist and they reckon the car should be able to go 20 miles below zero before running out of fuel and it should stop the car starting unless of course it is empty. My PAssat ussed to go 4 miles below zero and never had a problem starting.
    I faield to mention the fact that the car doesn't actually turn over when the problem arrisies, it's as if the emobiliser is active. I am not sitting there turning it over trying to start it.
    Jul 2011
    mids
    1,193
    Well that changes things then so could be the starter motor or immobiliser issue.....
    A4 TDI 130 SPORT..
    Jun 2011
    1,344
    i have vcds pro if you want it looking at
    Jul 2011
    mids
    1,193
    Quote Originally Posted by gen.heinz guderian View Post
    Perfect start and a great offer I'd say
    A4 TDI 130 SPORT..
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    Many thanks for the offer mate, how much do you want for scanning it, and when are you free?
    Jun 2011
    1,344
    im free this afternoon , NR146HD no 46 opposite turning for Autotechnic Merc specialists
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,420
    the immobilizer will still let the car turnover
    you have a bad starter or a wireing problem
    Oct 2009
    Hull
    1,437
    Re: S4 won't start, please advise?
    Next time you go out to it try and start with the door open you may hear the starter click every time you try it could be a sticking solenoid I have the same problem on my tdi I started a thread not too long ago
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    i do get a click but not a large load click like what you'd expect from a solenoid, but you could be onto something Stu.
    Mar 2008
    1,040
    can you here the fuel pump prime up ?
    Oct 2009
    Hull
    1,437
    Quote Originally Posted by GeoffDunk View Post
    yup sounds like its the same as mine its not a massive click but you can hear it
    dont forget its in the engine bay so you wont hear it that loud
    it could be one of two things a sticking solenoid or the actual starter not turning and the gear sticking on the fly wheel
    you could always try and rock it in gear if it is the gear sticking it will free it
    Jul 2011
    mids
    1,193
    Hope it's the starter and not the flywheel ring gear....
    A4 TDI 130 SPORT..
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    CHeers Stu, sounds very much like my problem, fuel pump primes and i get the click.
    Oct 2009
    Hull
    1,437
    Quote Originally Posted by marktdisport View Post
    if the ring gear was shafted you would still hear the starter turn over
    Jun 2011
    213
    99% starter, i had exactly the same with my s4 it would be fine for days on end then go to it in the morning and nothing. i would try different keys etc the same as you with no joy then go back to it an hour later and it was fine. i had mine reconditioned and it would appear its very common on the s4 but is a bit of a swine of a job although mine was much easier as the engine was out at the time!
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    547
    THis all got started, it was the starter motor, replaced with recon unit for £80 and all is good.
    Amazing how tiny the starter motor is too.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    Jun 2011
    213
    it barely looks big enough to start a lawn mower does it!
  1. Replies: 9
    Last Post: 7th February 2012, 18:20
  2. Car won't start - HELP PLEASE
    By Donny_DJ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th October 2011, 00:47
  3. Added tuning box, now won't start HELP PlEASE :-(
    By Mrlewty in forum General Automotive Chat
    Last Post: 23rd March 2011, 06:36
  4. Cut out at traffic lights and won't start again..please help!!
    By rlc1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2010, 08:32
  5. A3 1.8T won't start in the mornings - Please Help!
    By A3Tomlin in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2010, 18:20
