AH FabricationsEM Tuning
    Mar 2008
    1,016
    Fitting bypass pipe
    Is it possible to fit a cat bypass pipe from only working from the top of the engine I cant see 2 bolts but therest I can see just fine .... So can you undo the 2 bolts I can't see from the top if it's possible it would only take 30 mins to fit
    Mar 2008
    1,016
    Anyone?????
    Mar 2008
    1,016
    Got bypass pipe fitted today not to bad a job only took 2 hours no ramp did it on jacks ... Go' s like hell now awesome
  1. N429 bypass pipe problem
    By s3clarke in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2012, 10:21
  2. cat bypass pipe 1.8t quattro
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th August 2012, 21:19
  3. remove prop shaft to fit down pipe ?
    By melon454 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2012, 09:43
  4. Pipe Fittings for a 710N valve.
    By AndymacA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2009, 21:31
