Volks AutosBadger5
Results 1 to 12 of 12
    Jul 2012
    Derbyshire
    306
    Reverse switch 1.8t 190
    Ok guys reverse lights not working changed bulbs and checked fuse but where is the reverse switch located on this engine
    Apr 2012
    129
    The reverse light switches are usually on the gearbox, I've only ever done one before on an astravan. HTH
    Jul 2012
    Derbyshire
    306
    Yeah thought it would be on the box somewhere but where ? Or would it be under the gear stick gator ?
    Jul 2012
    Derbyshire
    306
    Come on you knowledgeable Audi owners someone knows
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    If you can make out from this picture. It seems to be next to the driveshaft but a bit lower.
    Hope that helps!
    Jul 2012
    Derbyshire
    306
    Mate that's great thanks is that the drivers side or passenger though
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    Honestly I can't say however have a quick look if there are any wires or connectors near both side.
    Jul 2012
    Derbyshire
    306
    Oh and just forgot to mention its 6 speed manual just incase theres other variations thanks again slick
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    Quote Originally Posted by Slinepete View Post
    I've compared both 5 & 6 Speed boxes and they both give the same pictures even with the diesels. So it should be good.
    Jul 2012
    Derbyshire
    306
    Thanks mate appreciate it that'll be my job tommorow then get a new part Tuesday thanks Pete
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    637
    When the switch is here you'll know which connector goes in so you don't need to fiddle much to find where the switch is.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    Think it's on the right if I remember correctly the same side as the exhaust....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. Part or Part code needed for Reverse switch connector?
    By reptor245 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 16:30
  2. Reversing light switch???
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2011, 16:15
  3. B7 1.9tdi manual reverse Light Switch
    By sspogman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th October 2010, 20:51
  4. Reverse light switch 1998 A4 20v
    By S3 Dave in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th June 2010, 18:39
  5. reverse switch
    By FazS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th July 2008, 21:16
