AH FabricationsBadger5
Results 1 to 10 of 10
    Jun 2012
    16
    Audi A4 B6 Passenger Door Has No Power and Door is Stuck Shut Help!!!!!
    Hi, My audis passenger is is stuck shut, has no power to the lock, window or electric mirror and I cant even open it to check the wiring joint in the door. Is there a back up way to open the door at all or am I screwed?
    Thanks for any help, i will reaaaaalllly appreciate it, thanks Dean
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    You're not screwed.... but you will need to try and force the door card off from the inside, hopefully you'll be able to get enough of the card away to enable you to pop the catch open. It does sound like the wiring is damaged at the hinge point. Good luck.
    Jul 2010
    Chelmsford, Essex
    46
    Morning,
    I didn't want to start a new thread so did a search and found this.
    My B6 Avant has the same problem.
    Passenger rear is stuck shut. At the weekend all the doors would lock/unlock apart from the NSR. I then managed to get it to lock but then failed again to re-open. To make matters worse I have the child lock on so cannot be open from inside either.
    I believe it's the wiring which has failed, making it not unlock or open.
    Is there anything I can do to get it to open?
    Is going into Audi next week but want to give something a go myself
    Michael
    Jul 2010
    Chelmsford, Essex
    46
    I took out the 4 screws from the doorcard yesterday, then tried to get the doorcard off, but with the door being shut I just could not get my fingers round it enough to pull it.
    I then noticed I could access the wiring loom from outside the car at the bottom of the B pillar. I pulled back the rubber sleeve but could not see any damage to the wires. It could well be damaged further inside or at another part of the loom.
    Any ideas how you'd get the door undone when the child lock is on?!?!
    Jul 2010
    Chelmsford, Essex
    46
    Well it's going into Audi today to see what the problem is, bound to cost me plenty of £££'s
    Will report back with their findings
    Jul 2010
    Chelmsford, Essex
    46
    Split wires in the B Pillar, as expected.
    No idea how they managed to get the door undone but they have.
    £101.20 all in for the repair
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by Silky View Post
    Sounds pretty fair to me!
    I'd be interested to hear how they did it.
    Sep 2009
    Rumburgh Suffolk
    193
    Me too, probably not much more than an hour or two's labour in all honesty, so didn't take them long...
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Mar 2008
    Dorset
    13,856
    Most dealers charge in excess of £120 per hour....
    Jul 2010
    Chelmsford, Essex
    46
    Car was in at Audi Colchester, used them quite a few times now and always seem very fair.
    They were working on the car for about 3hrs or so, only charged me labour and parts to do the repair, nothing to get the door open.
    I was told that it took them a while to work out how to get it open, but they didn't tell me how they did it.
  1. Passenger window has mind of its own!
    By Raveydavey in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2010, 11:52
  2. My door has dropped
    By tazzy baby in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd December 2009, 13:31
  3. Audi 80 1.9 TDI Loss Of Power Stuttering
    By StompOn in forum Diesel forum
    Last Post: 22nd August 2009, 09:00
  4. Audi A3 1.9 Tdi 130cv - Mb Power
    By goodspeed in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2009, 21:39
  5. Owning an Audi was a dream that has turned into a nightmare
    By MatLamont in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2008, 22:45
