I have a problem with my AWX engine on the Audi A4. Just noticed recently that I am losing power - as in torque.
I remember before it used spin its wheel due to the massive torque, but now it doesnt seem to do this and seems like not enough power.
I plugged VCDS in and the MAF (actual) is much higher than than the specified which isn't normal; right? If I disconnect the plug to the MAF there seems to be no power @ all to the car.
Also when revving to the redline whilst on neutral it seems to be hessitant on the 4000rpm mark for about a fraction of a second - with a LOT OF BLACK SMOKE!
I've noticed the black hose going into the turbo seems to have quite a bit of soot on it aswell as the oil return pipe - Does that indicate something?
The car has power and DOES NOT go into Limp or anything like that, and showing NO errors
Should I require to give more information through VCDS let me know.
