Results 1 to 8 of 8
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    B6 premature wheel bearing wear.
    Jumped in my A4 which my Wife now drives to find a wirring noise at anything over 30. Cornering to the right, it gets slightly worse. Took it to my dealers today and it was diagnosed with wheel bearing wear with only 12,000 on the clock, 2 yrs old!.
    Will be taken care of under warranty thanks to my friendly local dealership. Apparently there is a newer style wheel bearing which supercedes the part.
    scoTTy's Avatar
    Essex, UK
    1,957
    Re: B6 premature wheel bearing wear.
    I've complained about a similar noise for the last three visits. I hope this is the cure!
    The911SC's Avatar
    Sep 2003
    1,032
    I think the S4 is a bit more noisy at the front end anyway, but you would know if you had this!....
    scoTTy's Avatar
    Essex, UK
    1,957
    Well I've booked it in three times to investigate a noise that I say is a bearing so my fingers are crossed.
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    I've just had mine replaced under warranty.
    Near side front bearing making a clunking noise going round a roundabout.
    Listers Worcester had the car on Wednesday morning, ordered the part and got the car back this morning.
    Top dealership with no Bul***t, get my vote everytime.
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    scoTTy's Avatar
    Essex, UK
    1,957
    Mine came back today with no fault found. I don't get a clonking (definately a problem) and it's being put down to tyre noise again. Maybe they are all like this. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    The911SC's Avatar
    Sep 2003
    1,032
    What tyres are you running?. The wheel bearing wear sounds like a groaning noise on mine noticable at speed (50-60), cornering to the right or left will indicate which it is more likely to be. I have had a car with tyre noise in the past and it did sound similar. If you have different front to back, swap them.
    scoTTy's Avatar
    Essex, UK
    1,957
    I'm running Michelin PS2s on my the OEM wheels and Goodyear F1's on the RS6 reps. Same noise with both henceI don't believe it's tyres.I've also down a front to back switch.
