Sky InsuranceBadger5
Results 1 to 7 of 7
    Sep 2006
    27
    improving fm radio signal?
    I have an Audi chorus cd changer/cassette head unit. Outside of town, picks up strong signal radio stations ok, albeit a bit fuzzy. As soon as I head into town, the signal just drops completely. This is on radio stations radio 1 and radio 2. Would it be a problem with my aerial, or connector into headunit, or something else?
    I live in Milton Keynes if that helps. Not really crawling with sky scrapers blocking signal lol.
    Oct 2009
    Hull
    1,437
    sounds like the amplifier for the aerial is kaput!
    Sep 2006
    27
    Where would that be located and is it something that can be replaced quite easily?
    Oct 2009
    Hull
    1,437
    Re: improving fm radio signal?
    If you look at the rear window from inside at the top there is a panel that you can just pull off and its behind there
    That's on the saloon anyway! Not sure on an avant
    Sep 2006
    27
    Ahhh brilliant cheers. Where can you get them from? Dealer only?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,538
    or VW TPS if you can get trade or know someone.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    LIVERPOOL
    Jul 2009
    LIVERPOOL
    39
    Your aerial amplifier must be cracked like mine it's a common fault, which Audi should replace for making a weak part.
    Here's a few threads about it which people have done some DIY fix.
    Easy-Cracked-Radio-Reciever-Fix
    General-Info-AM-FM-Antenna-Booster
    I tried the fix and it's alot better than what it was.
    I hope the new revised part is built better for that price.
  1. Cab radio signal...
    By Louis Cronin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st September 2012, 10:16
  2. Intermittent Radio Signal - 2005 A4 Cab - Please Help !
    By Lord Bigfoot in forum In-Car Entertainment
    Last Post: 22nd May 2010, 19:26
  3. Radio signal amplifier (how to fit?)
    By audi lover in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2010, 20:04
  4. BOSE sub / aerial not picking up radio signal
    By twofivenine in forum In-Car Entertainment
    Last Post: 24th January 2007, 16:50
  5. Radio Signal Amp??
    By Beerzo in forum In-Car Entertainment
    Last Post: 13th January 2007, 21:39
