AH FabricationsSky Insurance
Results 1 to 9 of 9
    Nov 2004
    St. Albans
    61
    does anyone else\'s Climate fan speed sit at one bar???
    A couple of mornings now I've noticed that the climate fan speed when on Auto stays at one bar for a number of minutes before eventually getting up to a faster speed. Could this indicate a need to recharge?
    imported_AndyB40
    Re: does anyone else\'s Climate fan speed sit at one bar???
    Most of the time, especially in this weather, soon as my car starts the bars climb rapidly as it tries to cool the car to the set temperature. However I too have noticed that occasionally it will just sit at one bar and do nothing. I end up having to manually change it, then a little later I press Auto and all is back to normal!
    imported_bubstar
    I think it takes a min or two to sort itself out before you get control over it. Sometimes I can't adjust fan speed at first....................
    BUB [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2005
    bristol, uk
    757
    Yeah mines the same. If the car is baking then it rockets up to max and your can't here yourself think. If it's not been hot in the car it may sit at 1 for some minutes before going to 2 or 3. I wouldn't worry about it.
    Mark
    Nov 2004
    St. Albans
    61
    cheers. The reason I'm paranoid is that in a couple of weeks I'm bombing down to north Italy and Croatia for a three week holiday, and I will really get it in the neck if the climate fails down there!!
    Mar 2004
    Yeah, i've noticed the same on mine, A4 1.9tdi. Just had mine recharged after front end smash, so it can't be that.
    phil1978's Avatar
    Dec 2004
    Home of the white stilleto
    183
    It's happened to mine a couple of times not all the time. All I done was pushed the ECON button the fan speed went up then swithced the ECON off and it was fine..... Hope this helps.
    imported_Wicked666
    it's just getting heaters hot/cool air cool before pumping it into the cabin.
    Sep 2003
    England
    33
    Wicked666 is right, on a cold day it won't turn the fans up until the heaters can actually heat the cabin. In contrast you'll notice that on a hot day it will start pumping air in really fast straight away because it's almost always cooler outside than in the cabin.
