AH FabricationsEM Tuning
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    2.5TDi Injector pump timing & Needle lift sensor.
    Just a quick question on timing up the fuel pump on the 2.5 TDi:
    Does the needle lift sensor need to be working when adjusting timing of the fuel pump?
    I checked initially with VCDS which told me that the timing was too advanced - moved the pulley quite a few times and tested but kept telling me that the timing was too advanced - it only increased the duty cycle according to VCDS.
    The needle lift sensor on the 3rd injector isnt working on mine, been putting off swapping it for a while but if its required to set the timing accurately I may aswell order one.
    Many thanks!
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Feb 2012
    Liverpool
    1,152
    I am just in the process of ordering now, I have found two part numbers/revisions for the injector, these are; 059 130 202 F/G
    I have spoken to Audi, they are not sure which one I have - F or G, will this matter? - I dont fancy removing the rocker covers again to find out!
    Many thanks!
    - Weitec GT
    Jul 2007
    London
    3,240
    Do you have a round connector or a square one ? Assuming your's a late b6 it should have the round connector. Most likely the one your's have is a F, the G one was fitted to BDG/BAU later cam roller engines, not that it matters much just they are limited in the tune ! Failing that you could swap the internals off your "bad" injector and fit it to the new injector so the nozzles are not much out of balance...
    FOR SALE:
    Feb 2012
    Liverpool
    1,152
    Quote Originally Posted by adamss24 View Post
    Thanks, Im not 100% sure on the connection shape - will check later on.
    Spoke to a bloke at TPS who said the same as you about the F revision, will call back and order - £285.
    - Weitec GT
  1. 00542 Needle lift sensor (G80)
    By dan1 in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th February 2012, 08:48
  2. A6 2.5Tdi injector pump removal.
    By Mrlewty in forum General Automotive Chat
    Last Post: 6th April 2011, 00:10
  3. 2.5TDI needle lift sensor
    By Mike B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th November 2010, 12:32
  4. V6 2.5TDI Injection Pump Timing
    By donsajid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th March 2010, 14:16
  5. Needle lift Sensor Fault
    By mimo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2009, 14:35
