Monster MotorsportBadger5
Results 1 to 18 of 18
    Sep 2005
    Staffordshire, UK
    455
    Confused with Steering Wheel Controller!
    Hi Guys,
    Looking at Cruise Control for my audi A4 Avant 2004 1.9TDI Sport.
    It has a 3 spoke steering wheel with on board computer (MPG/Length Driven) but no Steering Wheel Controls.
    VAG com/VCDS lite say the VAG NUMBER is 8E0 953 549S which on RossTechs site says is not compatable with Cruise control and requires updating.
    TPS with my VIN number says my Steering Wheel controller should be fine and checking finer details on Ross Techs site my coding says its coded as a 3 Spoke Steering Wheels which should have a compatable controller!
    any ideas...is VAG com giving me an incorrect part number?
    If I have On Board computer...it must have a suitable Steering Wheel Controller?
    any help appreciated...different between a £100 bill and £300!
    Rich
    Audi Avant A4 54 1.9Tdi Quattro & Leon Cupra R 2005 1.8T remapped to 275bhp
    Oct 2009
    Hull
    1,442
    all modules do on board computer but only mid to high end ones do 3 spoke steering wheel
    i would take the steering cowling off and check what number is written on it!
    amz
    Sep 2011
    184
    Hi mate, unfortunately the part numbers ending with the letters 'F' and 'S' are not compatible. I had to upgrade my steering module too to the 'Mid' line/'High' line, in order to enable cruise control.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Quote Originally Posted by amz View Post
    +1
    My 2005 S4 had an S suffix SCSM which I had to swap when I wanted to add cruise control.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Sep 2005
    Staffordshire, UK
    455
    HI guys,
    Looks like its bad news then, but will DOUBLE check...
    Can I check which cowling needs to be removed to get to the Part Number??
    Is it just the two torx bolts on the cowling....
    Rich
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    If VCDS say's its the 'S', then its the S. Can't really trust TPS to see what parts are installed tbh.
    You can easily do a visible check without removing the steering wheel.
    Remove the 2x T8 Torx Screws from the bottom cowling, this will release the top cowling and allow you to flip the cover back to reveal a white sticker.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Sep 2005
    Staffordshire, UK
    455
    I take your point....VCDS will be reporting accuratly! Doh! just didn't want to think about the additional cost...
    anyone know how much the Steering Wheel controllers are? Is there much point getting a Highline one over a mid line? apart from the highline allows for Heated Steering wheel which I will never have!
    I guess its checking the price of them all and which one is the cheapest..
    Sep 2005
    Staffordshire, UK
    455
    And final question....doesn't a yellow wire have to be fitted with a new steering wheel module as well?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    Just get any module that doesnt end in a S or F and you'll be grand.
    Theres a few on the bay for around £85.
    You dont need to install a yellow wire.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    no
    Sep 2005
    Staffordshire, UK
    455
    Fab guys, cheers... whats the yellow wire about then :S
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    Where did you hear about a yellow wire?
    Sep 2005
    Staffordshire, UK
    455
    Quote Originally Posted by jb0o View Post
    Yellow wire mentioned alot here: Another cruise control question
    Seems to be about the washer bottle sensor which I do have..
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,577
    That is for DIS, but you can simply ground pin one of the blue dash plug.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Sep 2005
    Staffordshire, UK
    455
    Quote Originally Posted by mjmallia View Post
    So I do need to do something with additional wires then?
    I have DIS already
    Oct 2009
    Hull
    1,442
    no as you have dis you will either have the washer level sensor or the pin will have been grounded already unless you have a washer level warning on your dash permanently
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,609
    As Stu said, if you already have DIS then dont worry about the wire.
    Sep 2005
    Staffordshire, UK
    455
    Cheers guys, top dollar.
  1. steering wheel controls?
    By curran33 in forum In-Car Entertainment
    Last Post: 17th July 2006, 16:21
  2. Steering Wheel Controls
    By mnadeem1984 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2006, 21:06
  3. s3 steering wheel controls for radio
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2005, 20:33
  4. retro fit tiptronic steering wheel controls
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2005, 14:34
  5. steering Wheel Controls
    By Broken Byzan in forum In-Car Entertainment
    Last Post: 30th August 2004, 14:19
