Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By demus
  • 1 Post By munchkincoupe
Thread: Which sidelight bulbs to match factory HID lights?
    lincoln_dj's Avatar
    Dec 2009
    Lincoln, England.
    137
    Hi Guys,
    I've got an S4 with factory-fit HIDs and just wondered if anyone could suggest a sidelight bulb that matches in colour to the HIDs, they are currently more yellow compared to the HIDs. Not bothered about light output since I never drive with just sidelights on anyway. Have found 1 other thread although not sure it was regarding factory or aftermarket HIDs...
    Anyone found a decent colour match bulb for your HID'S??
    That mentions getting LEDs, which obviously need to not give any errors! Do these look any good...?
    LED SMD PARKING LIGHTS BULBS AUDI S4 B6 Cabriolet | eBay
    501 W5W SMD LED Parking Bulbs Lights AUDI S4 B6 8E | eBay
    Any recommendation more than welcome, especially if accompanied by pics!!
    Also suggestions for main beam while i'm at it, although light output would be more important than colour for those!!
    Cheers, Adam.
    2004 A3 3.2 V6 manual
    deana4's Avatar
    Jan 2011
    county durham
    29
    Be careful buying led side light bulbs. I bought some for mine and all they did was flash as soon as the hid kicked In, I bought some more incase they were dodgy bulbs and the next set were even worse
    May 2011
    136
    One of mine melted the bulb holder then broke off inside the headlight ! Worst mod I've ever done !!
    Sep 2009
    Rumburgh Suffolk
    188
    If your car has bulb failure built into the DIS, make sure the LEDs pull enough current to keep it happy, otherwise it'll keep bleating about them, and the side lights will seem to flash.
    I bought some a while ago, they are about 20mm long and have about 15 LEDs on them, and pull nearly as much current as the standard bulb, keeping the DIS happy, and they look great..
    They will flash about 4 or 5 times quickly then stay off when you turn the ignition on, this is normal and is just the DIS checking all the bulbs, with standard filament bulbs you dont notice it, but LED's react so quickly you'll see it. Leave your car parked heading up to your house at night and try it, soon as you turn on ignition they'll flash real quickly.
    Unlike some lesser cars you don't have to use the lights for the car to know one has failed
    lincoln_dj likes this.
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    munchkincoupe's Avatar
    Aug 2010
    971
    PM T8ups on here - he sells led bulbs that are a good match and are durable with no errors
    lincoln_dj's Avatar
    Dec 2009
    Lincoln, England.
    137
    Cheers for the feedback peeps
    demus - which ones did you use?
    munchkin - will do, cheers!
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I used UltraLEDs.co.uk for my sidelight bulbs, but have since discovered T8ups on this forum for my boot lights... no complaints for the service / products* from either.
    *about 3 years ago, I had one LED fail from ultraLEDS and when I mailed them, they replied straight back with: "not a problem, no need to send it back, we know we had a bad batch and we're replacing all failures immediately", 2 days later, I had replacements for all 4 that I'd ordered (the rest did fail fairly quickly, but their replacements have lasted nearly 3 years so far)...
    Just remember that factory HID headlight units require different sidelights:
    Sidelamp bulb for HID-equipped cars - H6W-12V6W
    Sidelamp bulb for halogen-equipped cars - W5W-12V5W
    If you still have the factory 4300K bulbs, I'd recommend getting a pure white, sometimes even described as a "warm" white... the ice-white ones have a very slight blueish tinge (probably match 5000K or 6000K better)... mine are 4300K + ice white LED's., it's not enough to bother me, but they're not a perfect match...
    Before:
    After:
    (yes, photo's taken at the same time, just half-way through the upgrade, left and right).
    LostBok/BahnStormer77
    Sep 2009
    Rumburgh Suffolk
    188
    Think they were something like these..
    501 Long 19 LED Extreme Power 2W
    Its guess work as to which way round to fit them as they are polarity sensitive, if the wrong way round you shouldn't damage them, they just won't light up..
    Mark
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Quote Originally Posted by demus View Post
    Demus, do you have factory fitted xenons? Reason I ask is that the factory-fit xenons have an offset bayonet fitment for the sidelight, so you can't fit them incorrectly, as per my previous:
    Quote Originally Posted by lostbok View Post
    Lincoln_DJ, it might be owrth checking that your HID's are 100% factory fit: the bulbs recommended by Demus won't even fit in a car with factory xenons, the link is to wedge-shaped W5W's (pic taken directly from the previous Demus link):
    If you have factory fitted Xenons you need ones that are the shape of the LED below (note this link is the new edition of the ones I had that overheated and rated at 6000K, so even if they don;t overheat any more, they're NOT a great match for factory xenons, but at least the connector is the right shape!):
    UH6W1W H6W BAX9 - 9mm BC Offset Pins Single Bulb by Ultra Leds U.K
    Just PM t8ups or start a thread here (Products), tell him that you've got a B6 A4, factory xenons (so you're after H6W's) and want some to match the OEM 4300K bulbs.
    I've only had limited experience with him (3 queries, 2 orders), but he seems really decent, knows his products and the postage is pretty prompt and his prices are great: plus it's nice to support somebody on the site.
    Sep 2009
    Rumburgh Suffolk
    188
    Nope, just standard H7 halogens for me, did upgrade them for a Philips bulb as the standard ones were a bit poo, same wattage but much brighter, pretty good now..
    Mark
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Nope, just standard H7 halogens for me....
    Thanks for confirming: just that Lincoln_DJ had asked for advice on bulbs to match his factory HID headlights and you gave him purchasing recommendations based on Halogen bulbs.
    Quote Originally Posted by lincoln_dj View Post
    I've got an S4 with factory-fit HIDs and just wondered if anyone could suggest a sidelight bulb that matches in colour to the HIDs...
    So I just wanted to make sure that you knew that they were very different in case anybody ever asked this question again: if he'd bought your recommendation, the only place they would have fitted would have been in the interior bulb sockets, not his sidelights.
    Sep 2009
    Rumburgh Suffolk
    188
    Fair doo's, my appologies, didn't realise they were different to tell the truth.... good job you noticed...
    Mark
    lincoln_dj's Avatar
    Dec 2009
    Lincoln, England.
    137
    Have just received W5W bulbs from Trups so would like to confirm the above it correct since these dont fit my OEM HID sidelights which are indeed H6W! Have asked him for H6W but if not i'll give that site a try mate.
    lincoln_dj's Avatar
    Dec 2009
    Lincoln, England.
    137
    Finally have some bulbs that fit so just posting an update for anyone else who searches for this in the future:
    Trups didn't have any offset bayonet type in stock so went for a pair from ebay in the end. Don't know if ebay links are allowed here but you'll want to search for "2x 8 SMD LED 433 434 BAX9S H6W OFFSET PINS CANBUS NO ERROR FREE SIDE LIGHT BULBS" or similar. The ones I bought were from someone called fizzmocouk.
    Took a pic to show the difference, unfortunately didn't take one with HIDs on too but they are a close enough match in my eyes. better than standard anyways. Passenger side (on the right in the pic) is the LED bulb.
  1. which sidelight bulbs to match my nightbreaker plus headlight ones?
    By allyp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2011, 18:24
  2. New Style Rear LED Lights/ sidelight bulb replacing
    By gazzaw888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2010, 22:14
  3. changin sidelight and dipped light bulbs to match xeons
    By ty160 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2009, 23:29
  4. Are these sidelight bulbs the ones i need to match a h.i.d kit???
    By M22_PRE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2008, 20:10
  5. hid lights on facelift headlights what bulbs will i need???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2007, 07:11
