    Gstar51's Avatar
    Mar 2012
    Leeds
    75
    Suspension top mounts.
    Finally going to fit my eibach springs at the weekend, so I thought it would be a good idea to put some new top mounts on at the same time. Any ideas for the best place to get these from???
    Avant 03 1.9 tdi
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    216
    Dont know if they are the same but I got new ones for my 1.8T Quattro from the local Audi Dealer with the washers and nuts for £55~ all in
    And it turns out i dont need them so they're going back today
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
    Gstar51's Avatar
    Mar 2012
    Leeds
    75
    Cheers dubbers, was that for both sides or each corner??
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    615
    Whats the symptoms if the top mounts are worn?
    Just curious as I have recently changes all front wishbones and link bars however still theres the metal ting noise. Not loud just makes the noise if I go over potholes however doesnt make the noise if I go over speed hump with both wheels.
    Sorry if I seem to be hi-jacking thread, but would be so relieved if this is cured.
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    216
    That was for the pair, turned out my clonking was coming from a slightly loose top arm
    VCDS HEX-USB+CAN
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    615
    All the arms been changed with along with the link bar amd tightened and double checked after a week if anything loose - all fine.
    Would it by any chance be the anti-roll bar bushes?
  1. Suspension Top Mounts
    By murphyslaw in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2012, 17:11
  2. S3 Top Mounts
    By Sandip in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2008, 21:28
  3. Do top mounts need to be changed on suspension kit?
    By sharma in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2008, 23:22
  4. S6 Suspension Top up
    By morty_mma in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th January 2007, 09:02
  5. Replacement Rear Top Mounts
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2006, 23:24
