Monster MotorsportChris Nott
Results 1 to 10 of 10
    Jul 2012
    24
    Switched ignition wire
    I'm trying to replace the factory head unit and I need a switched ignition wire i.e. power comes on when ignition comes on, I've taken the panel below the steering wheel off but I'm not sure which wire to use for switch. I've looked online and searched everywhere but no one has a posted a definitive location of where to wire it from.
    Could some one tell me which one to wire it to and what gauge wire I should use to.
    Oct 2009
    Hull
    1,442
    In the big bunch of wires there is a thin red wire that is switched live
    You will need a relay too as it will burn out if you wire straight to it
    Jul 2012
    24
    the big bunch of wires going to the fuse box?
    and what kind of relay, a 3 pin? and how would I got about wiring the relay?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    just wire stright to the fuse box
    no relays needed
    theres 3 switched lives in there
    Jul 2012
    24
    Which fuse is the switched live, I read through the list and I couldn't figure out which one would be switched live
    bez101's Avatar
    Jul 2008
    8,530
    get a multi on it and chect i dont know location off hand
    Oct 2009
    Hull
    1,442
    Quote Originally Posted by Mizan View Post
    Sorry wires going to ignition
    If you want the radio to stay on till you pull the key out use the thin wire on the ignition I'm not sure if the ones on the fuse box stay live with the key in I'm sure someone can verify
    You need a 4 pin relay
    Jul 2012
    24
    does it matter if I don't connect the red and the big black plugs? I have the rear amplified system and not the bose, I am going to order some harnesses that do connect to them, but I don't have them atm. And do I just need a switched live to work or will I need to ground it aswell?
    and for the relay, how would I wire the 4pin relay? I assume the wire on the ignition would now go through the relay, but how would I wire the switch? would I have to get a 12v power from somewhere else?
    thanks
    Jul 2012
    24
    I've managed to wire my head unit up now so it works fine but i've got 2 problems, the first is I need A illumination line to dim the head unit, what wire should I use behind the sidelight switch? and the second problem is that when the stereo is loud and there is loud base, the head unit cuts out, like the sound distorts then cuts out, any ideas why? thanks
    Aug 2010
    1,540
    id suggest getting a professional to do this for you before you end up with a vehicle fire. lol.
    no offence but, just like i'm a house diy retard........ you sound like a car diy retard!
  1. Ignition Live Wire/Switched Live??
    By lockie2002 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2011, 20:21
  2. H/U ignition wiring...
    By fenian672000 in forum In-Car Entertainment
    Last Post: 12th December 2006, 09:51
  3. Ignition Wiring Issues
    By imported_GarretLogan in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th May 2005, 10:22
  4. Ignition Switch
    By imported_kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2004, 15:20
  5. Switched live wire?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2004, 10:30
