Chris NottAH Fabrications
    climte control codes
    Is it possible to access the cars computer via the climte control on a B6?? I have used it on my old 1999 a4 but the same process doesnt seem work on the b6.. was it disabled on this model or is it a different process?
    Oct 2009
    Hull
    1,437
    No you need VCDS for that on the b6
  1. retrofit cruise control coding and activation issue
    By deian3387 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2012, 18:58
  2. Airbag controller coding
    By Fox in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd April 2010, 15:06
  3. Climate Control Codes
    By gaz71 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2010, 18:04
  4. Cruise control coding A3 8P
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th February 2008, 17:13
  5. A3 T Climate controle Factory Codes
    By razor in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2004, 17:05
