Monster MotorsportChris Nott
Results 1 to 21 of 21
    Oct 2009
    Hull
    1,433
    Intermittent none starter!
    I have a 2002 1.9tdi and every now and then when you turn the key there is nothing
    all the lights come on as usual but when you go to start there is nothing at all not even a click!
    any ideas? I was thinking starter solenoid or something
    Jun 2010
    East Manchester In the Hills !
    597
    Starter solenoid, faulty immobiliser or a battery with bad cells in it IMO
    Oct 2009
    Hull
    1,433
    Thanks for the reply
    I can rule out the battery for a start as I know this is fine
    I cant see it been the immobiliser to be honest as it would start then die thats how the immobiliser works on these but stranger things have happened
    I've had solenoid problems before on a bike and it acts exactly the same so I'm 90% sure it will be that
    so where the hell is it? any ideas? I will check it out first as it could just be a bad connection which I very much doubt
    Jun 2010
    597
    No idea on a 2002 TDi. If it was a petrol AUM I am your man as I have had plenty of starters off a Mk4 golf !
    I hope you get it sorted and started if you can excuse the pun
    Oct 2009
    Hull
    1,433
    I have just read that it maybe next to the ECU I will check my haynes book of lies and see what that says
    also read that it can throw up a code when the solenoid is loose or failing so will do a scan too
    ps The car still starts just every now and then it is just dead!
    Jun 2010
    597
    Can't see it being next to the ecu. Starters are always next to the flywheel. I would be looking down the right hand side of the engine near the gearbox. You may have to remove it from underneath the car
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    Yep sounds like the starter motor, my old B5 1.9tdi had the same fault. If I kept the key turned it would go after about 5 seconds but it got worse and worse. It was more of a problem in winter for some reason.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Jun 2010
    597
    The cold makes the grease go sludgy and hangs up the solenoid piston. The other fault is that it engages and turns the car over, but then stays engaged and the flywheel then spins it at high speed and throws it out. Sounds awful when it happens but all too common on a car of this vintage. Just ask any mk4 golf owner.
    You can strip the motor down and regrease if your handy and want to save a few quid. Most just rip it off and get a recon unit.
    Oct 2009
    Hull
    1,433
    Quote Originally Posted by lgooch View Post
    I read somewhere that there is a starter relay near the ECU that can work loose and cause the same problem how true it is I don't know and whether its for a petrol or diesel!
    I will do some poking about and also remove the starter and give that a bit of a bash
    AU01 A4's Avatar
    Jan 2009
    Huddersfield
    211
    get it scanned as it could be crank sensor (g28)
    Audi A4 1.8T quattro S Line Avant
    Oct 2009
    Hull
    1,433
    I scanned it last night it came up with nothing
    Aug 2012
    GOT A 2004 2.5TDI WITH THE SAME PROBLEM AHD IT SCANNED NO PROBS FOUND..PROBLEM NOT ALWAYS THERE SO I AM GOING TO RUN THE CAR TOMORROW TILL THE NON START HAPPENS AND THEN I WILL CHECK THE FEED TO THE STARTER MOTOR ..WILL REPORT BACK WITH FINDINGS.....
    Oct 2009
    Hull
    1,433
    I was on it today funny enough
    It's the starter solenoid it keeps sticking so I'm going to get another starter for mine
    I figured it out by chance it wouldn't do it when trying to test then jumped in the cap with the window down and you could hear the starter click on each try
    pauldazzle's Avatar
    Cardiff
    549
    Quote Originally Posted by stu_m View Post
    It's the solenoid that's clicking so it's probably ok. Sounds to me like the starter motor is goosed.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Sep 2009
    Rumburgh Suffolk
    175
    Or the contacts in the back of the solenoid... must admit I normally end up changing the whole lot
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    Oct 2009
    Hull
    1,433
    I will be changing the starter it only ever seems to happen to me its never happened to the missus and she uses the car more then me!!
    when it totally packs up and she has to get recovery I will buy one lol
    May 2012
    78
    If the solenoid it gubbed then you would get a 'click' sound - if teh brushes in the starter itself are worn out - it wont even click. But wither way - it will be drawing current in the start position, therefore the ignition lights would dim when you turn the key fully... Is this the case?
    If not, then its not the starter.
    Aug 2012
    hi my 2004 2.5 tdi automatic a4 was a non starter today after we had done a 2 mile journey. did notice this time that when i turned the key to the start position and the engine did not crank the footbrake light near the gearstick was not lit.....when i tried to start the car 4 hrs later the light was on and the car started ...could this be a immobiliser problem or a neutral position sensor problem any ideas
    Oct 2009
    Hull
    1,433
    Re: Intermittent none starter!
    It's not the immobilizer as it would start and then die
    Aug 2012
    HI EVERYONE
    LOCATED PROBLEM TODAY RELAY LOCATED IN THE ECU BOX UNDER THE SCUTTLE PANEL DRIVERS SIDE HAD SOME SIGNS OF HEAT DAMAGE ...THIS RELAY HAS A FEED FROM THE STARTER SWITCH AND ALSO GIVES A PICK UP TO THE GEARBOX INHIBITOR SWITCH COST £12......THANKS FOR YOUR HELP
    Jun 2010
    597
    Glad you have it sorted
  1. Intermittent Brake warning light - WEIRD
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:20
  2. HELP PLEASE!!!!!!! Intermittent brake lightfailure
    By howard in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2003, 23:20
  3. J(92) Audi 80 Sport Intermittent fault
    By clarkee123 in forum Classic Audi Forum
    Last Post: 17th November 2003, 21:44
  4. Need some help none car related work pranks
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2003, 18:39
  5. Intermittent Fault Warnings
    By A4Owner in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2003, 11:23
