Volks AutosJMB Retrofits
Results 1 to 14 of 14
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Dreaded Airbag light
    Ive read through what i can find, but am i right in thinking only Audi can reset the light?
    What is the usual cause of it coming on?
    I recon my other half moved the passenger seat and may have caused it. Not too sure though
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Jun 2011
    213
    think you can reset it without going to audi and the most common cause on most cars seems to be switch/connection under seats someone more knowledgable will be along soon to assist you further im sure
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    Yes, look under the seats, there's a little plastic cover - pull it up and check that the airbag connector is firmly in (yellow one). I'm not sure about making the light go out, I always VCDS. Maybe try taking the battery off for a while?
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    batt off wont reset the bag light a handheld reader vcds dealer local garage will sort it
    very common for it to be a connection under the seat to the back not the cover on the floor
    get it scanned if it wont stay off once reset you need to do a small repair on the connector,
    bez101's Avatar
    Jul 2008
    8,491
    get the fault code if it stays on after reset do this
    DIY: B6/B7 Airbag light (Audi TSB)
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    you need the code deleting by a code reader, i have one if your close ?
    beachbuggy's Avatar
    Surrey
    1,744
    As above, just done it on mine. Remove cover under seat, unplug yellow connector, spray with isoprol spray and clean terminals. Then you need a full bag con to reset. Total task takes less than 5 minutes so don't pay silly money for it or find someone with vagcom to do it.
    Jun 2011
    Great Melton Norfolk
    1,349
    you can scan airbags and clear the fault with vcds, look on the user map to find some one near you
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Once again some great advice. Love this forum (dont tell the wife i said that)
    I had a butchers under the seat at the said plugs and wiggled them about. Seems all fine to me. The plastic clip under the passenger seat that holds the wires up is broken, but all wires seem fine too. I will unplug and clean them up then its time to find someone close to Sheffield with VCDS.
    Off to the Lake District in the morning, so it will have to wait till i get back. Soooo good to know i may not have a major issue.
    Time to test out my new tyres on the windy roads while trying to take in some of the views
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Quote Originally Posted by Turkster View Post
    Thanks, i may take up your offer, will see if anyone is available closer first.
    Oct 2009
    Hull
    1,440
    I'm in hull if that's any good?
    bez101's Avatar
    Jul 2008
    8,491
    IM in sunny sheff
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    IM in sunny sheff
    Cheers, will give you a shout when i get back off my hols
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Quote Originally Posted by stu_m View Post
    Bez is in Sheffield, thanks again
  1. A6 tdi airbag light on! looking at purchasing car?
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th January 2005, 21:57
  2. Passenger Airbag Light
    By steveh in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 14:29
  3. abs airbag light
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2004, 18:46
  4. Airbag Light
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 16:18
  5. Horn / Airbag light problem
    By MikeS in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 17:46
