Chris NottJMB Retrofits
Results 1 to 7 of 7
    Mar 2008
    1,053
    think i might of found my problem bang
    last night before wife got out the car i popped the bonnet open to check oil level as i lifted bonnet my wife got out the car and i noticed the engine rocked quite alot over to the right as i look at the engine .. could this be the problem sound im hearing ... passenger engine mount gone maybe .... but im sure i can here the sound on drivers side when im in the car .. this there a way to check mount with out removing it ? as i took a gamble on drivers side and turned out to be ok ... any help on this ????????
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,569
    Sounds like an engine mount is shot. Your best bet is to take the lower engine cover off and locate all the mounts.........watch them by lying on the floor while your wife revs the engine to pin point and make sure its a mount, which I think it is.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    bowen's Avatar
    Mar 2011
    456
    You and this bloody knocking! You got arond ten threads on this knocking lol. I can understand the frustration.
    Open the bonnet and give the engine a good shake, literally grab it and shake it!
    Audi A4 B7 SE S line TFSI Quattro.
    Mar 2008
    1,053
    Quote Originally Posted by bowen View Post
    done that and it deffo makes a bang sound .. all this bloodytime wasted on drivers side ... i would of bet money it was drivers side too...
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    you cant always tell if they are busted until you take one off, that's how i found my one
    May 2012
    78
    The only way you can propoerly tell is get a pry-bar and lever the engine at each of the mounting points - whichever mount give the most movement is the culprit.
    Just general visual checks or rocking the engine wont really tell you anything!
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    One of best ways with handbrake on and another person taking up the drive to biting point will rock the engine to the max so you'll see and hear any excessive movement.
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. newby here. I think i'm having head gasket problems
    By nico2000 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2010, 19:55
  2. Replies: 6
    Last Post: 10th September 2010, 08:54
  3. fitted my bargin but have i found a problem
    By pagey in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th February 2010, 22:12
  4. Finally found my problem
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2009, 11:01
  5. i might have a turbo problem?i need some help
    By 97_A4_1.8Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2008, 14:08
