AH FabricationsJMB Retrofits
Results 1 to 10 of 10
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    Towbar fitment, electrics setup
    As above, fitting a towbar this week, it comes with single electrics, just wondered if any one knew how the b6 electrics output works, is it jut plug and play, or do I need a relay??
    Next Steps. (wanted)
    s`line steering wheel
    oem interior mods
    milltek exhaust system..
    window tints.
    Nov 2011
    South Lanarkshire
    81
    Hi Bean5Wire Colours on diagram -
    ws= white
    sw = black
    ro = red
    br = brown
    gn = green
    bl = blue
    gr = grey
    li = purple
    ge = yellow
    or = orange
    rs = pink
    Hope this helps...
    I've just done this last week. The easiest way to do the electrics is to purchase a bypass relay.I fitted this behind the rear trim in the boot close to the 12v aux socket.The wires from your 7 core cable connect to one side of the relay,and the other wires connect to the the car electrics.. The above diagram should help you out but its from a lhd vehicle but colours were the same..
    hth M
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    Thanks bud! That's saved me a load of time!!!
    oem interior mods
    window tints.
    Nov 2011
    South Lanarkshire
    81
    I used scotch lock connectors to attach to the car wiring.. I also attached the power to the boot 12 v aux socket and ran 2 wires over to the passenger side to do the tail and brake light.
    M
    May 2012
    78
    I would go down the relay route for sure - the Audi electrics require them.
    Scotch locks are a bit dubious tbh and can fail
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    I also have a question about towbars, so will hijack the thread (if you don't mind).
    I was looking at this towbar: here
    Under in the options it suggests an audi dedicated wiring loom. Is that not necessary then? Will the bypass relay work just as well, or am i getting the wrong end of the stick?
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    The dedicated wiring loom would hopefully have connections into the K-Line / CanBus so that when correctly coded, the car will behave correctly when the trailer is attached.
    The Bypass relay just allows the towbar to be wired without the car knowing..
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    7 WAY SMART MULTIPLEX RELAY, BYPASS RELAY - AUDI | eBay
    is this wat i need?? i still not 100% on what i need to do. have you fitted your towbar recently too? did you have to take our rear bumper off?? if so do you remember what tools were needed, going to attempt mine this week but will need to bring tools home from work. lol
    oem interior mods
    window tints.
    Nov 2011
    South Lanarkshire
    81
    Yes relay looks the same as what I used.
    To remove the rear bumper you'll need 10mm socket and some torx keys.I'm sure I used a T15, T20 and a T30. Also sockets or spanners to suit nuts snd bolt on the towbar,usually a 17mm,19mm and 24mm.Possibly a hack saw if you've to trim the bumper.
    1)Remove the spare wheel compartment cover.
    2)Remove the two nuts holding the black plastic trunk trim, just behind the spare.
    3)Remove the four luggage net hold down clips.
    4)Peel back the carpet from around the sides which is also pushed under the black plastic trunk trim. This is spring clipped in place. There are also two plastic screw clips in the top of the liner above the shock towers.
    5)Behind the trim you will now see a vertical line of four nuts with plastic point covers on the protruding bolts. (Beneath the rear lights)There are also two more of these in a vertical line inboard of the four. (six total each side)pull off the plastic cap and remove the nuts.
    6)Remove two screws underneath the valance, in board of the exhausts attaching the valance to the frame.
    7)Remove two Torx screws each side inside the wheel well holding the carpet liner in place.
    8)Remove the Torx screw that is behind the liner. This holds the valance.
    9) Pull the sides of the lower bumper away from the side of the car.
    10)The whole unit will now pull off in one piece.
    Fit the towbar and then re-install everything.
    description was for a saloon.
    HTH M
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    nice 1 bud!!
    oem interior mods
    window tints.
  1. Towbar fitment
    By moggie93 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd March 2012, 22:40
  2. Audi S3 towbar fitment
    By kularm in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2011, 17:37
  3. towbar electrics, wiring diagram?
    By pablo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th March 2008, 10:02
  4. Towbar electrics
    By oilyaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2007, 08:17
  5. A3 towbar electrics
    By ScottTDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2006, 20:33
