    britpop95's Avatar
    Mar 2011
    Wigan
    22
    does anyone think there should be an earth here? (with picture)
    Does anyone think there should be an earth lead here this is on the back of my alternater on my 52 130 TDI. Tryna find out why my battery keeps draining??? Thanks in advance to anyone who helps much appriciated.
    Apr 2012
    202
    Nope not for an earth usually a cable holder bolts on there. The alternator earth is through its body onto the engine block. If the charge is ok around 14 volts with the engine running then I would rule the alternator as ok. More possible something isn't switching off with the ignition off and draining the battery. You need to carry out a current draw test on the vehicle with it in its locked state.
    britpop95's Avatar
    Mar 2011
    Wigan
    22
    cheers for that mate i will check that out.
    27,121
    Remove the radio, see if this helps.
  1. Hi there does anyone have Installed Pics of this RS4 Style Grille??
    By mybadassA4 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 10th February 2013, 21:35
  2. Replies: 4
    Last Post: 5th July 2010, 19:05
  3. anyone thinking of or have lowered there s3?
    By Gary b in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2009, 18:41
  4. Does anyone think that.....
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2005, 17:06
  5. Does anyone check their MPG?
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 08:22
