Volks AutosMonster Motorsport
    Jul 2012
    Inverness
    Dual Temperature Sensor help
    Hi guys , I have a 2003 A4 1.9 tdi quattro, temp gauge hasn't worked for a couple of years and I had heard that if the temp
    sensor isn't working , the ECU still thinks the engine is running cold and uses more fuel?
    Is this the case as round town driving I get mid to high 30's , when I go on a journey I get mid 40's.... I wouldve thought 50+ would be easily achievable.
    However , I've now discovered the part I need is called a dual temp sender .... does mean that 1 part tells the temp gauge what the temp is and the other part tells the ECU?
    Hope this makes sense to somebody
    Any thoughts/wisdom welcomed
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    To be honest after a few people on here with 1.9 Q say they only get mid 30's and there's a few fwd only doing mid to high 30's.. My fwd comes in as average around 42-45 mpg but if I do 550 miles then 400-410 will be dual Carriageway to work @ around 65-70 mph...on a very long journey it will creap to a near 50 driven carefully.. The temp sensor will work in a few ways but they all do.. Should just be a simple change over
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    Just get your temp gauge fixed, usually only the thermostat or coolant temp sensor.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    pauldazzle's Avatar
    Cardiff
    558
    Temp sensor failure is one of the most common failures on VAG cars.
    Yes the CTS has 2 outputs 1 to the gauge & 1 to the ECU. If the ECU is getting incorrect reading from the CTS it won't fuel correctly. Make sure you get a genuine VAG replacement (£25ish) Aftermarket CTS's are notorious for failing.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat pipe, 165bhp remap, EGR delete, Dunlop SP Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
  1. Temperature sensor help please
    By s3black in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2011, 12:05
  2. Where is Coolant Temperature Sensor? Help please!
    By Pom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd September 2011, 15:28
  3. BAD o2 sensors (help)
    By A-Wagon in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2006, 13:16
  4. Temperature Sensor - Display
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2005, 20:39
  5. Replies: 1
    Last Post: 16th May 2004, 11:04
