EM TuningChris Nott
Results 1 to 10 of 10
    Jul 2012
    Chester
    Water Ingress into Footwell
    Hi All
    I have an 04 Audi s4 Cabriolet, lately I have been suffering with water coming into the driver's side footwell (only) I have had to scoop the water out on a regular basis (up to 3 pints once).
    The water appears to occur when it has rained quite hard, I have had the gutter channels under the battery checked and this is all clear and working. It appeared the 1st time when I drove through a very deep puddle which came up to the cill, the next day it was flooded. The water always appears to be a dirty grey colour (this maybe the colour of the carpet running)
    I took it to my Audi dealer and they wanted £300 just to detect the fault!! (very helpful as usual).
    Can anybody help me with my dilemma
    Stuart
    Feb 2011
    littleborough lancs
    224
    try your door / window seal,
    the pasenger side is the moste comon affected with water when the plenum chambers are blocked, but theres no reasom i can think of that meen your driver side wont get wet too, is everything under the bonet ok. no holes where a rubber plug or bung as i call them is missing??
    just a thought, hope you sort it
    p.s. is your seat or the dash wet?
    bowen's Avatar
    Mar 2011
    456
    Ok, I have an Audi Cab and very recently had the same problem. Things to do;
    Watch this 1999 Audi A6 Water Leak DIY Tutorial - YouTube its for an A6 but very similar.
    And this Water Igress - ECU Leak - YouTube
    However mine turned out to be neither. Water would enter my car through the apperture seal, a seal that runs down the side of the windscreen, past the hinge of the door and along the driver side sill. Squeeze this seal and feel for water.
    Hope this helps?
    Audi A4 B7 SE S line TFSI Quattro.
    Jul 2012
    Chester
    Quote Originally Posted by saxonblue View Post
    Hi saxonblue, That was the 1st thing I had checked and all was good there. No the seat and dash are dry so it's not a roof leak if that's what you were thinking. Thanks for your reply
    Jul 2012
    Chester
    Hi bowen
    That sounds like it might be the solution as my door rubber has been worn away by the previous owners dragging their feet whilst getting in the car. Looking at this seal there is water in the cavity of the rubber when it rains quite hard.
    Many thanks for your reply..............Off to order a new door seal!!!
    bowen's Avatar
    Mar 2011
    456
    If you havent already ordered it I know of a solution.
    Jul 2012
    Chester
    I haven't yet ordered it..................What is your solution because I know the door seal is £150 + VAT + Labour
    bowen's Avatar
    Mar 2011
    456
    Yeah expensive...
    Right imagine two straws laying next to eachother, this is what that seal looks like in simple terms.
    Ok, follow the seal down to the drivers sill plate. Lift it off the body work and look at the underside, you will see two holes which are there as an over flow drain (in one straw). Put something sharp in the hole and pierce the rubber on the other straw. DONT GO ALL THE WAY THROUGH, YOU WILL PIERCE BOTH STRAWS!
    I do hope this explains it clear enough?
    Jul 2012
    Chester
    Quote Originally Posted by bowen View Post
    Yeah expensive...
    Hi again Bowen
    Thanks for the instructions, I tried having a quick look last night and sorry I couldn't quite understand what you were trying to explain to me...............Sorry, but thanks all the same!
    bowen's Avatar
    Mar 2011
    456
    After I read it I was slightly confused by myself,I will explain again;
    The apperture seal ressembles two rubber straws laying next to eachother. One rubber straw (straw A) has two holes in it to let water flow out, however the second straw (straw B) is the one which is full of water and is leaking into the cabin.
    Get a sharp object and access straw B through the holes already there in straw A, pierce straw B and water will flow out.
    I dont know if that is any clearer? sorry if it isn't
  1. Water Leak in Footwell
    By lilya in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2008, 11:22
  2. Water leaking into footwells
    By spinaltap in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2007, 12:13
  3. water leaking passenger footwell
    By solihul in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2006, 21:43
  4. Water leak into rear footwell
    By AndyMac in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th November 2005, 17:45
  5. Leaking into Footwell
    By EoD in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 09:07
