Chris NottMonster Motorsport
    Nov 2011
    South Lanarkshire
    75
    electrics problems/ wiring diagram needed
    Hi there,
    I'm in the middle of fitting a towbar to my b6 avant.I'm trying to work out the connections in the rear lights. I have removed both rear lights so I can get at the plugs to trace the correct wire. When I turn on the side lights my front side lights flash constantly.
    My side lights are led ones and have had no problems with them so far.
    Anyone have any idea what will be causing this?
    Does anyone have a copy of the wiring diagram for the rear lights so I can find the correct wires to connect to.
    Thanks M
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    520
    Here we go, I have assumed you have the highline computer installed in your car (you get bulb-out warnings on the dash) as I believe the wiring is slightly different for highline/lowline.
    Wire Colours on diagram -
    sw = black
    ro = red
    br = brown
    gn = green
    bl = blue
    gr = grey
    li = purple
    ge = yellow
    or = orange
    rs = pink
    Hope this helps...
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    Nov 2011
    South Lanarkshire
    75
    Thanks benjie, is the diagram for a left hand drive? reason im asking is it shows a left hand fog light. No wiring colour for ws.
    Thanks M
    Nov 2011
    South Lanarkshire
    75
    All sorted now.. Thanks benjie..
    Oct 2009
    520
    Sorry, just seen this. Glad it's all sorted. For reference, (if anyone else needs this info) ws was code for white wires and the diagram shows all lights coming from the J519 (onboard power supply unit) to each rear light.
  1. Help needed with an electrical issue. (Wiring Diagram needed)
    By Wiganer in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2011, 10:48
  2. Replies: 0
    Last Post: 4th May 2011, 16:58
  3. A4 1.8Turbo 2002 Instrument cluster wiring diagram Needed,
    By Ciaran in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2010, 22:28
  4. towbar electrics, wiring diagram?
    By pablo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th March 2008, 10:02
  5. STEERING / ELECTRICAL PROBLEM!?!??! HELP NEEDED!?!?!?
    By Baker21 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th June 2007, 14:20
