Chris NottVolks Autos
Results 1 to 8 of 8
Thread: 1.8t wastegate?
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    1.8t wastegate?
    I've got a very audible air release/whooshing sort of noise when my car hits peak boost (23psi) from low revs, once I'm giving it some it doesn't overboost and runs around 18psi, I've been told this could be my wastgate not holding pressure, it still has a slight fluctuation in boost pressure aswell, could this be a result of my n75 needing replacing? Thanks
    A4 b6 1.8t 190 sport Quattro avant revo stage 1
    beachbuggy's Avatar
    Surrey
    1,727
    Dv valve is shot if it's whooshing, you won't hear a waste gate .
    If the waste gate was faulty you definitely wouldn't hit 23 psi.
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    I thought dv but got told its more likely that the wastgate isn't holding pressure properly
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    Hi, I refitted the stock dv, same thing happened, now got a new forge dv and still the same, could it possibly be the n75 going bad, it also still fluctuates between 15 and18psi and you can feel it holding back, only other thing I can think is inlet manifold leaking somewhere, my boost gauge connects from vacuum line on inlet?
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    Or could it possibly be due to intake temperature which is why it still shows good boost?
    Feb 2011
    littleborough lancs
    207
    mine makes a mad sound too, ( mi did a thred on it)
    put its like a fast ticking, what causes that
    hitman1978's Avatar
    Apr 2012
    castleford
    105
    i did wonder about intake temps, it definately pulls better before its fully up to temperature, might have to try and clean out my intercoolers, anyone know if this is a difficult job to do? also if i fit a intake temp gauge where would i fit it from and what sort of temp should i be looking to achieve, thanks
    Sep 2011
    73
    you can log intake temp on vag com, had a leak on mine and that was teh "suction jet pump" big plastic valve with nrv's in it at teh back of the inleyt manifold near cyl number 4 neearest bulkhead on top of engine
  1. kkk k03, no wastegate = no PSI =no boost
    By import in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2005, 21:23
  2. possible Wastegate Problem
    By pinochio in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2004, 09:13
  3. Is it my wastegate I can hear
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2004, 09:31
  4. Rattly Wastegate
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th December 2003, 12:10
  5. Wastegate actuator
    By Steve1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2003, 23:38
