Monster MotorsportChris Nott
Results 1 to 13 of 13
Thread: Thick smoke
    Jul 2012
    17
    Thick smoke
    Hey guys god I'm putting up lots of posts lol
    My Audi a4 2.5tdi each morning when I start it it doesn't start as soon as I turn the key I have to wait for it for about4-6 seconds, and then when it does start and I rev it it brings out some grey thick smoke and quite alot comes out... What may the reason be for this?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Sounds like it needs Glow Plugs mate.
    Does it start better when its hot ?
    Jul 2012
    17
    Yes deffo when the weather is ether I don't have to wait that long holding the key but still let's out a good blow of smoke
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    glow plugs
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Its smoking because your having to crank it for longer fires up befor itdue to suspected faulty glow plugs.
    Jul 2012
    17
    Is this a big problem or minor?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Pretty minor.
    Jul 2007
    770
    My 2.5tdi doesnt need glowplugs this time of year and will start as soon as I switch on.No need to wait for the light to go out only when its much colder.It used to be a bad starter until the cambelt was changed and it was retimed by an expert who found it was well out before
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    sounds like pump timing aswell to me. mine will fire after a second of crank without plugs in summer everytime cold or hot. you can have the timing checked and adjusted quite easily.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The smoke is just unburnt fuel as the diesel is being cranked into the cylinder before it fires.
    You need to establish why it won't start, on the 2.5 it's typically glow plugs (unlikely at this time of year), a weak battery, a faulty coolant temperature sensor, or (most likely) your fuel pump timings is out.
    Glow plugs are £20 ish x 6 and a DIY job if you're competent.
    CTS is £30.
    Battery is whatever, £80 ish typically.
    Fuel pump timing is probably an hours labour for someone with VCDS.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    id also check pump timing firstly..
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Jul 2012
    17
    Wait you said battery!!! Could it be battery?? Because my window wipers at one point just got ever so weak it used to lift up n stop before getting to the end so it could come back again,, I had to keep trying every ten mins... But thankfully that's gone now
    Jul 2011
    mids
    1,193
    theres also a common issue with slow wipeers in the sticky section id say oump timing and your wipers are another issue, if the car runs the charge rate should be around 14v so plenty of power m8
    A4 TDI 130 SPORT..
  1. 1.9 130bhp thick black smoke
    By mark a4 tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th May 2009, 18:37
  2. Smoked Rear Light Lenses for 2003 A6 Saloon
    By cliffcartwright in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2003, 14:28
  3. Smoking Kenwood Stereo!!
    By Naresh in forum In-Car Entertainment
    Last Post: 4th October 2003, 00:01
  4. Smoking Brakes
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 18:42
  5. Clifford Smoke Alarm
    By Moresauce in forum Other Brands & Models
    Last Post: 11th January 2003, 12:54
