JMB RetrofitsEM Tuning
Results 1 to 8 of 8
    munchkincoupe's Avatar
    Aug 2010
    971
    Interchangeable centre caps
    How interchangeable are Audi wheel centre caps - I'm after a set of 8T0 601 170 for my new wheels as the current ones have seen better days
    All of the sets on ebay are different codes or cheap replicas - would 8D0 or 4D0 code centre caps fit too?
    Jun 2011
    130
    60mm are what you need i believe, i got mine from ebay standard audi 4 ringed ones, genuine parts
    £10 delivered made a big difference aswell !
    Aug 2010
    971
    The ones I need to replace are 63-64mm across the face or 53-54mm across the compression ring!
    Jun 2011
    130
    60mm will fit perfectly
    Aug 2010
    971
    Thanks will order some then - fingers crossed
    Aug 2010
    971
    Quote Originally Posted by boomtown View Post
    Thanks for that . . . . . . . . if by fit perfectly you mean they wobble about and then fall out
    60mm don't fit
    Anyone need 4 new centre caps - 4B0 601 170 ?
    Jun 2013
    Hi. I know it's been a while, but what did you wind up doing for center caps? I'm in the same boat you were. The 8T0 601 170 is hard to find unless you want to pay $50 each from the dealer or order from some sketchy site online.
    Aug 2010
    971
    Got 2 from the dealers in the end
  1. Centre caps for 17" RS4 original wheels
    By BobB in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2004, 12:27
  2. Fitting OEM Centre Caps to RS4 Replica Rims
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th May 2004, 13:30
  3. Centre Caps for A6 Alloys
    By Harj in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th May 2004, 20:08
  4. Porsche centre caps
    By jimboA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2004, 14:25
  5. RS4 copies - centre caps
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2003, 19:01
