Results 1 to 18 of 18
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Aircon moisture buildup query
    I've got a water leak in the cabin.
    On Thursday my passengers floor mat had water droplets all over it. Not thinking to much about it I dryed it off and carried on.
    Yesterday the same thing happened.
    The weather has been close but very wet up here in Scotland. I've had the aircon on flat out for 3 days at 18c or at LOW position.
    So today I stripped the glove box out and noticed water dripping from the blower motor. Removed the motor expecting to see water coming from the pollen filter housing. But nothing wet further up. It seems to be within the blower motor assembly.
    Could it be possible that the cold aircon air is creating that much condensation / moisture ?
    Has anyone else experienced this ?
    Andi.
    APAutomotive's Avatar
    Shark Performance Shropshire
    Mar 2012
    Telford, Shropshire
    76
    Pollen Filter seal leaking?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Quote Originally Posted by APAutomotive View Post
    I did suspect the pollen filter housing but it seemed dry above the motor. I've stripped, cleaned and sealed the pollen filter housing. It did seem a little damp around the seal.
    Hope that fixes it.
    Mar 2012
    Telford, Shropshire
    76
    make sure your plenum drain hole is free from debris aswell as this may cause water to build up causing all sorts of issues
    Andi25th's Avatar
    May 2010
    Inverness
    226
    The plugs were removed ages ago. So I can rule that one out.
    Just back from a run in the car and even more water dripped on to the mat.
    I'll remove the glove box and monitor it. As the bottom of the blower motor was soaking again.
    Hate water leaks.
    Apr 2012
    202
    Check under the car with the AC on maximum cold to see if the heater box drain is ok.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,751
    I agree, it sounds to me like the evaporator drain is blocked.
    Mar 2012
    Telford, Shropshire
    76
    As above, check heater box drain
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Ok thanks lads. Will get it up on a ramp tomorro. Where is the drain located ?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Is this the top of the drain pipe ?
    Mar 2008
    Dorset
    13,751
    Potentially, I'm not sure where it is to be honest.
    Mar 2008
    Dorset
    13,751
    Elsawin's a bit vague, these may help:
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Big thanks to all that's helped.
    The problem has now been resolved.
    The culprit was the Aircon drain pipe. It's very squashed as not to take up space. It was completely blocked up. I removed it washed it through and checked the valve at the end by blowing it through.
    Almost a pint of water and debris was removed in total.
    Thanks again to all that's contributed.
    Mar 2008
    Dorset
    13,751
    This has been asked before, are you able to take a picture of where it is?
    Lancaster
    1,654
    As per James post. Any heads up of how to do the job?
    To do: None yet.
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Remove glovebox and associated trim.
    Pull back carpet to reveal Aircon drain tube located to the right of the passengers footwell.
    The tube should look like this:
    Sorry about the quality of the picture, my flash died.
    Once you have located the drain tube. Remove by pulling from the bottom first. As my one was blocked to the top I got a jug ready to catch the liquid when removing the tube from the top.
    Once removed clean tube thoroughly.
    When I refitted the tube I fitted it to the bottom first and blew through to check the lower valve was clear.
    I then switched the Aircon on to full cold which blew the rest of the remaining water out of the system. Refit tube to top hose and refit glove box etc.
    Hope that helps any further questions please ask via pm.
    Mar 2008
    Dorset
    13,751
    Thanks, so it's easy enough to push it out through the bottom of the car again then?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    The tube in the picture pushes in to a rubber grommet that's fixed in to the floor. So its easy enough just to pull it out and push it back in.
  1. new aircon control unit - query
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd March 2011, 15:24
  2. Some queries about my new S3
    By robthehungrymonkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2004, 19:26
  3. AIRCON RECHARGING
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th April 2004, 10:10
  4. Brake Query?
    By adjturbo in forum General Chat
    Last Post: 5th November 2003, 13:19
  5. Suspension Query..
    By Lowride in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2003, 01:31
