Volks AutosEM Tuning
    crazypainter's Avatar
    Jun 2010
    Surrey
    587
    wheel bolts and the void behind the hub??
    I am looking at which wheel bolts i need. I am just wondering how much, if any, a wheel bolt can stick past the back of a hub?
    Need pinstriping? : www.crazypainter.com
    A4.. 1.8T.. Remapped .. Saloon.. Atlas Grey.. Votex Kit..
    Apr 2012
    202
    Standard wheel bolts are 27mm in length. If running spacers add the thickness of spacer to 27mm then round it up as longer bolts only come in 5mm different lengths.
    Jun 2010
    Surrey
    587
    I have non standard wheels to put on and the standard threads barely grab one turn into the hubs so i have to get longer ones but I am unsure if its ok to have a any excess length passing into the apparent space behind the hub, and if so, how much?
    Mar 2008
    1,015
    you must have at least ten full turns on a wheel bolt to be safe
    Apr 2012
    202
    Are you using the original wheel bolts with the after market alloys? The after market alloys will have a different seat type for the bolts. You should be ok with 27 or 30 mm length bolts with no spacers. I have run wheels with spacers in the past and had about 4mm extra thread more than I have needed and they have been fine. Rule of thumb is 7 turns of thread is needed.
    Aug 2010
    1,540
    being that the standard pitch of the wheel nuts are 1.5. every full turn of the wheel bolt pulls it in by 1.5mm.
    so if your bolts currently only go in by 1 turn then ideally they need to be about 9mm longer.
    as been said. the shoulder of the bolts against the wheel need to match, some are curved shoulder some are flat. this is important to stop them coming loose, as when the bolt is torqued up the friction against the two surfaces is what holds the bolt tight.
  1. Replies: 15
    Last Post: 8th February 2012, 14:24
  2. How many mm's or threads of the wheel bolts should go into the hubs (2001 s3)
    By hank3944 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd January 2012, 09:42
  3. Hmmm, wheels back and on the car...(no 56k)
    By imported_Stewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2006, 17:38
  4. Newbie and wet behind the ears
    By Geronim0 in forum Detailing
    Last Post: 10th April 2005, 00:54
  5. Changing the Bulb behind the heater dials.......
    By GarryX in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2005, 13:41
